W Fri, 26 Apr 2024 04:15:00 +0000, Judge Porter napisal: So I made the mistake of watching it. From start to finish. Two people were at their respective podiums. A girl, perhaps the plaintiff and a...
read more »
This is not a final, adopted action. This has been circulated for tentative consideration by the Commission at its Open Meeting. The issues referenced and the Commission's ultimate resolution of those...
Using Astronomy as the template for these hierographs, the 30-square Senet format follows the classic 36-decan zodiac, such as depicted in extant ancient stone or wood artifacts and complementary...
Shift register are the registers which are used to shift the stored bit in one or both directions. In this section, shift register is implemented which can be used for shifting data in both direction....
HI All, I'm looking for the 7412, and 9412 handlers.... I see that someone had a phone number listed to get handlers. Is this still valid. I seen mention of C601 handler which I do have. I also have...
Wonder how many people will remember the Simi Valley based Micom Communications Corporation that was very active in the early days of Voice over Data (pre VOIP)? Their Marathon product was light years...
I have been using X-10 with a CP290 Interface for almost 19 years. It's worked very well for me, for the most part. I use it to control all the lights inside and outside my home. I had problems in the...
I have a small home network: laptop, Linksys WAG160n router, and Epson SX600F wireless printer. I rarely turn off my laptop (just shut the lid and put it to sleep) and never turn off the printer or...
Has anyone used a Raspberry Pi ZeroW (or another Pi, plus a USB WiFi adapter) as a WiFi router? As my existing WiFi router already connects to the internet using a USB mobile broadband modem, this...
I read an article that says you can substitute ground for neutral when wiring an x10 switch. Something tells me if this workaround was a good idea I'd have heard more about it. Comments anyone?
Hi, can someone please give some background on ethernet performance testing and throughput measurement applications like netperf, ttcp and if there are any limitations/disadvantages associated with...
Does anyone know of any apps that would allow me to use a USB CM19A on Windows 10? It worked fine on Win 8, but I can't find anything that works under Win 10.
I tried to get hold of you for quite some time today via the phone...I needed a pci-mini and some other stuff. Since I couldn't get hold of you today, I picked one up elsewhere :-(. Hopefully we cross...
Hi, was looking for some advice on a cabling job we had completed in our office. Its cat6 (well they used cat6 faceplates and cable). I've posted an image at: about 30 points, 3 don't work at all...
Well it looks like I've found the source to a recent spat of control problems. It's my new laser printer. Here's what happens: when the laser printer starts up there is a sudden dip in the power...
To Paul's point, I recommend two companies, both out of San Jose, but both do mail order (one via distributors like Amazon). More importantly, both give you specification sheets galore. o And both,...
Ok, here is my minor problem. I use Cisco Works LMS 2.5, and have lately discovered, as time goes on, the new switches we get etc, don't display properly in the topology map; they have question marks...
Hey Guys!! Anyone ever use a IEI MiniMax3 Access Control?? I know that it has...
As I mentioned a few weeks ago, I was given a Google Pixel Fi phone by a kind...
Hello all, I know almost nothing about telecommunication, and google also did...
What's goin on with everyone? . I've got a 2500 sqft single story house under...
Hello, I have a TV inside an entertainment center with doors. I would like a...
ASAI link are used to deliver the ANI/CLID to applications. ASAI interfaces to...
Programmed hundreds of Vista-15P's and 20P's of that vintage and never ran into...
We are looking to install a security system on our house. Our initial research...
Touch-Tone telephone dialing (commonly called push-button dialing) made its...
Hi all I am an awful story teller so I'll get right to the point. If someone...
Maybe you have some really bad cables in general? Copper is copper. I've...
Just curious: Does anyone make an LED lightbulb that has internal circuits...
