Cisco 1841 and SDSL WIC Card
Jan 16, 2008 2 Replies
Hi
I have a CISCO 1841 router with a ADSL WIC in it. I decided to add a CISCO SDSL WIC in it. But I am unable to configure it from the IOS software as I cannot see it
Can any one point me in the right direction
here are the output from sh ver and sh diag
Clearly the diag can see it, but when I do show interface it does not show up, it only shows the ADSL interface
++++++++++++++++++++++++++++++++++++++++++++++++++++++ show diag Slot 0: C1841 2FE 2SLOT Mainboard Port adapter, 4 ports Port adapter is analyzed Port adapter insertion time unknown EEPROM contents at hardware discovery: Chassis MAC Address : 001d.71d7.ed64 MAC Address block size : 34 PCB Serial Number : FOC11364UZD Hardware Revision : 7.0 Part Number : 73-8191-08 Board Revision : C0 Top Assy. Part Number : 800-23434-06 Deviation Number : 0 Fab Version : 04 CLEI Code : IPM7W00CRA RMA Test History : 00 RMA Number : 0-0-0-0 RMA History : 00 Product (FRU) Number : CISCO1841 Version Identifier : V05 Processor type : 86 Chassis Serial Number : FCZ114091K5 EEPROM format version 4 EEPROM contents (hex): ...
WIC/HWIC Slot 0: GSI GSHDSL MULTI LINE ATM WIC
Hardware Revision : 0.0 Top Assy. Part Number : 800-26571-02 Board Revision : C0 Deviation Number : 0 Fab Version : 01 PCB Serial Number : FOC11473840 RMA Test History : 00 RMA Number : 0-0-0-0 RMA History : 00 Version Identifier : V02 Product (FRU) Number : WIC-1SHDSL-V3 EEPROM format version 4
WIC/HWIC Slot 1: DSL SAR (ADSL)
Hardware Revision : 2.3 Part Number : 73-4771-09 Board Revision : C0 Deviation Number : 0-0 Fab Version : 05 PCB Serial Number : FOC11355HRC RMA Test History : 00 RMA Number : 0-0-0-0 RMA History : 00 Product (FRU) Number : WIC-1ADSL= EEPROM format version 4 ....
++++++++++++++++++++++++++++++++++++++++++++++++++++++ show ver
Cisco IOS Software, 1841 Software (C1841-BROADBAND-M), Version
12.4(16a), RELEASE SOFTWARE (fc2) Technical Support:
(c) 1986-2007 by Cisco Systems, Inc. Compiled Mon 10-Sep-07 07:24 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
yourname uptime is 32 minutes System returned to ROM by power-on System image file is "flash:c1841-broadband-mz.124-16a.bin"
Cisco 1841 (revision 7.0) with 113664K/17408K bytes of memory. Processor board ID FCZ114091K5
1 DSL controller
2 FastEthernet interfaces
1 ATM interface DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
31360K bytes of ATA CompactFlash (Read/Write)
Configuration register is 0x2102
conf t controller dsl 0/0 line-term cpe mode atm line-mode ... ....
Looks like you have a DSL controller. You should be all set. After you do your controller dsl 0/0 commands, you should have an ATM 0/0 interface.
