No sound but ringing if configured E1 to have 30 channels
Aug 23, 2006 10 Replies
Most relevant reply
MdV
The problem solved. Just to share with everybody here. The router CISCO2651XM is using NM-HDV where 'codec complexity medium' is the default. Beside that, g729r8 is a high complexity codec, again, this is default. With both mismatch DEFAULT, all the problem comes in. To solved…
Partial configuration based on Cisco doc "Cisco 2651XM Gateway - PBX Interoperability: Ericsson MD-110 PBX using Q.931 BRI User Side Interface to an H.323 Gateway", "Cisco 2651XM Gateway - PBX Interoperability: Nortel Meridian Option 11C PBX using Q.931 PRI Network Side Interfaces to an H.323 Gateway" and "Cisco IOS Voice Gateway - PBX Interoperability: Ericsson MD110 Release BC12 SP5 to E1 QSIG with H.323".
Hi steve,Sorry,Thank you for you help. I'm novice and I don't the way to...
M
MdV
Site A:
! version 12.4 service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption ! hostname LUTONG-GW ! boot-start-marker boot-end-marker ! enable password cisco ! no aaa new-model ! resource policy ! clock timezone MY 8 no network-clock-participate slot 1 no network-clock-participate wic 0 voice-card 1 dsp services dspfarm ! ip subnet-zero ip cef ! ! no ip dhcp use vrf connected ! ! isdn switch-type primary-qsig ! ! voice call send-alert voice rtp send-recv ! ! ! ! ! ! ! ! ! ! ! ! ! ! controller E1 1/0 pri-group timeslots 1-31 description Connection to LUTONG PBX ! ! ! interface FastEthernet0/0 no ip address shutdown duplex auto speed auto ! interface Serial0/0 ip address 144.199.160.2 255.255.255.252 no fair-queue no dce-terminal-timing-enable ! interface FastEthernet0/1 no ip address shutdown duplex auto speed auto ! interface Serial0/1 no ip address shutdown no dce-terminal-timing-enable ! interface Serial1/0:15 description D-Channel For PBX no ip address isdn switch-type primary-qsig isdn overlap-receiving isdn incoming-voice voice isdn contiguous-bchan isdn bchan-number-order ascending no cdp enable ! ip classless ip route 0.0.0.0 0.0.0.0 144.199.160.1 ! ip http server no ip http secure-server ! ! ! control-plane ! ! ! voice-port 1/0:15 description voice port for PBX ! ! ! ! ! ! dial-peer voice 99 voip destination-pattern .T progress_ind setup enable 3 session target ipv4:144.199.160.1 tech-prefix 99 dtmf-relay h245-alphanumeric ! dial-peer voice 88 pots destination-pattern 88T progress_ind alert enable 8 direct-inward-dial port 1/0:15 ! ! line con 0 line aux 0 line vty 0 4 password cisco login ! ! end
Site B:
! version 12.4 service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption ! hostname KLCC-GW ! boot-start-marker boot-end-marker ! enable password cisco ! no aaa new-model ! resource policy ! clock timezone MY 8 no network-clock-participate slot 1 no network-clock-participate wic 0 voice-card 1 dsp services dspfarm ! ip subnet-zero ip cef ! ! no ip dhcp use vrf connected ! ! isdn switch-type primary-qsig ! ! voice call send-alert voice rtp send-recv ! ! ! ! ! ! ! ! ! ! ! ! ! ! controller E1 1/0 pri-group timeslots 1-31 description Connection to KLCC PBX ! ! ! interface FastEthernet0/0 no ip address shutdown duplex auto speed auto ! interface Serial0/0 ip address 144.199.160.1 255.255.255.252 no fair-queue no dce-terminal-timing-enable ! interface FastEthernet0/1 no ip address shutdown duplex auto speed auto ! interface Serial0/1 no ip address shutdown no dce-terminal-timing-enable ! interface Serial1/0:15 description D-Channel For PBX no ip address isdn switch-type primary-qsig isdn overlap-receiving isdn incoming-voice voice isdn contiguous-bchan isdn bchan-number-order ascending no cdp enable ! ip classless ip route 0.0.0.0 0.0.0.0 144.199.160.2 ! ip http server no ip http secure-server ! ! ! control-plane ! ! ! voice-port 1/0:15 description voice port for PBX ! ! ! ! ! ! dial-peer voice 88 voip destination-pattern .T progress_ind setup enable 3 session target ipv4:144.199.160.2 tech-prefix 88 dtmf-relay h245-alphanumeric ! dial-peer voice 99 pots destination-pattern 99T progress_ind alert enable 8 direct-inward-dial port 1/0:15 ! ! line con 0 line aux 0 line vty 0 4 password cisco login ! ! end
J
James
OK this is a basic ISDN problem it has nothing to do with your VoIP codec or the I MB line.
You need to make sure that the PBX has the same amount of timeslots configured as the router it connects too. You can run between 1 and 30 timeslots on an E1, the choice is yours, however the Router and PBX it connects too must match.
James
MdV wrote:
J
James
Sorry - I didn't see the part where you say that you have configured the PBX for 1 - 15 timeslots.
Have you got enough DSP's > OK this is a basic ISDN problem it has nothing to do with your VoIP
M
MdV
Thanks for the reply.
This is the test I've carried out.
PABX (NT) Router (KLCC) Router (Lutong) PABX (Ericsson) Result
1-15 1-31 1-31 1-15 OK
1-30 1-31 1-31 1-30 X
1-15 1-16 1-16 16-30 OK
16-30 1-16 1-16 16-30 X
1-15 1-31 1-31 16-30 X
16-30 1-31 1-31 16-30 X
16-30 16-31 16-31 16-30 X
Can you explain to me, what is the ISDN issue? Maybe this can narrow down the problem?
PABX (KLCC) [Nortel Meridian 1
ld 20
PT0000 REQ: prt TYPE: tie TN 3 CUST DATE PAGE
TN 003 01 TYPE TIE CDEN SD CUST 0 TRK PRI2 PDCA 1 PCML A NCOS 0 RTMB 13 1 B-CHANNEL SIGNALING TGAR 0 AST NO IAPG 0 CLS UNR DTN CND WTA LPR APN THFD XREP BARD CLID P10 VNL TKID DATE 9 FEB 2006
TN 003 02 TYPE TIE CDEN SD CUST 0 TRK PRI2 PDCA 1 PCML A NCOS 0 RTMB 13 2 B-CHANNEL SIGNALING TGAR 0 AST NO IAPG 0 CLS UNR DTN CND WTA LPR APN THFD XREP BARD CLID P10 VNL TKID DATE 9 FEB 2006
TN 003 03 TYPE TIE CDEN SD CUST 0 TRK PRI2 PDCA 1 PCML A NCOS 0 RTMB 13 3 B-CHANNEL SIGNALING TGAR 0 AST NO IAPG 0 CLS UNR DTN CND WTA LPR APN THFD XREP BARD CLID P10 VNL TKID DATE 9 FEB 2006
TN 003 04 TYPE TIE CDEN SD CUST 0 TRK PRI2 PDCA 1 PCML A NCOS 0 RTMB 13 4 B-CHANNEL SIGNALING TGAR 0 AST NO IAPG 0 CLS UNR DTN CND WTA LPR APN THFD XREP BARD CLID P10 VNL TKID DATE 9 FEB 2006
TN 003 05 TYPE TIE CDEN SD CUST 0 TRK PRI2 PDCA 1 PCML A NCOS 0 RTMB 13 5 B-CHANNEL SIGNALING TGAR 0 AST NO IAPG 0 CLS UNR DTN CND WTA LPR APN THFD XREP BARD CLID P10 VNL TKID DATE 9 FEB 2006
TN 003 06 TYPE TIE CDEN SD CUST 0 TRK PRI2 PDCA 1 PCML A NCOS 0 RTMB 13 6 B-CHANNEL SIGNALING TGAR 0 AST NO IAPG 0 CLS UNR DTN CND WTA LPR APN THFD XREP BARD CLID P10 VNL TKID DATE 9 FEB 2006
TN 003 07 TYPE TIE CDEN SD CUST 0 TRK PRI2 PDCA 1 PCML A NCOS 0 RTMB 13 7 B-CHANNEL SIGNALING TGAR 0 AST NO IAPG 0 CLS UNR DTN CND WTA LPR APN THFD XREP BARD CLID P10 VNL TKID DATE 9 FEB 2006
TN 003 08 TYPE TIE CDEN SD CUST 0 TRK PRI2 PDCA 1 PCML A NCOS 0 RTMB 13 8 B-CHANNEL SIGNALING TGAR 0 AST NO IAPG 0 CLS UNR DTN CND WTA LPR APN THFD XREP BARD CLID P10 VNL TKID DATE 9 FEB 2006
TN 003 09 TYPE TIE CDEN SD CUST 0 TRK PRI2 PDCA 1 PCML A NCOS 0 RTMB 13 9 B-CHANNEL SIGNALING TGAR 0 AST NO IAPG 0 CLS UNR DTN CND WTA LPR APN THFD XREP BARD CLID P10 VNL TKID DATE 9 FEB 2006
TN 003 10 TYPE TIE CDEN SD CUST 0 TRK PRI2 PDCA 1 PCML A NCOS 0 RTMB 13 10 B-CHANNEL SIGNALING TGAR 0 AST NO IAPG 0 CLS UNR DTN CND WTA LPR APN THFD XREP BARD CLID P10 VNL TKID DATE 9 FEB 2006
TN 003 11 TYPE TIE CDEN SD CUST 0 TRK PRI2 PDCA 1 PCML A NCOS 0 RTMB 13 11 B-CHANNEL SIGNALING TGAR 0 AST NO IAPG 0 CLS UNR DTN CND WTA LPR APN THFD XREP BARD CLID P10 VNL TKID DATE 9 FEB 2006
TN 003 12 TYPE TIE CDEN SD CUST 0 TRK PRI2 PDCA 1 PCML A NCOS 0 RTMB 13 12 B-CHANNEL SIGNALING TGAR 0 AST NO IAPG 0 CLS UNR DTN CND WTA LPR APN THFD XREP BARD CLID P10 VNL TKID DATE 9 FEB 2006
TN 003 13 TYPE TIE CDEN SD CUST 0 TRK PRI2 PDCA 1 PCML A NCOS 0 RTMB 13 13 B-CHANNEL SIGNALING TGAR 0 AST NO IAPG 0 CLS UNR DTN CND WTA LPR APN THFD XREP BARD CLID P10 VNL TKID DATE 9 FEB 2006
TN 003 14 TYPE TIE CDEN SD CUST 0 TRK PRI2 PDCA 1 PCML A NCOS 0 RTMB 13 14 B-CHANNEL SIGNALING TGAR 0 AST NO IAPG 0 CLS UNR DTN CND WTA LPR APN THFD XREP BARD CLID P10 VNL TKID DATE 9 FEB 2006
TN 003 15 TYPE TIE CDEN SD CUST 0 TRK PRI2 PDCA 1 PCML A NCOS 0 RTMB 13 15 B-CHANNEL SIGNALING TGAR 0 AST NO IAPG 0 CLS UNR DTN CND WTA LPR APN THFD XREP BARD CLID P10 VNL TKID DATE 9 FEB 2006
TN 003 16 TYPE TIE CDEN SD CUST 0 TRK PRI2 PDCA 1 PCML A NCOS 0 RTMB 13 16 B-CHANNEL SIGNALING TGAR 0 AST NO IAPG 0 CLS UNR DTN CND WTA LPR APN THFD XREP BARD CLID P10 VNL TKID DATE 9 FEB 2006
TN 003 17 TYPE TIE CDEN SD CUST 0 TRK PRI2 PDCA 1 PCML A NCOS 0 RTMB 13 17 B-CHANNEL SIGNALING TGAR 0 AST NO IAPG 0 CLS UNR DTN CND WTA LPR APN THFD XREP BARD CLID P10 VNL TKID DATE 9 FEB 2006
TN 003 18 TYPE TIE CDEN SD CUST 0 TRK PRI2 PDCA 1 PCML A NCOS 0 RTMB 13 18 B-CHANNEL SIGNALING TGAR 0 AST NO IAPG 0 CLS UNR DTN CND WTA LPR APN THFD XREP BARD CLID P10 VNL TKID DATE 9 FEB 2006
TN 003 19 TYPE TIE CDEN SD CUST 0 TRK PRI2 PDCA 1 PCML A NCOS 0 RTMB 13 19 B-CHANNEL SIGNALING TGAR 0 AST NO IAPG 0 CLS UNR DTN CND WTA LPR APN THFD XREP BARD CLID P10 VNL TKID DATE 9 FEB 2006
TN 003 20 TYPE TIE CDEN SD CUST 0 TRK PRI2 PDCA 1 PCML A NCOS 0 RTMB 13 20 B-CHANNEL SIGNALING TGAR 0 AST NO IAPG 0 CLS UNR DTN CND WTA LPR APN THFD XREP BARD CLID P10 VNL TKID DATE 9 FEB 2006
TN 003 21 TYPE TIE CDEN SD CUST 0 TRK PRI2 PDCA 1 PCML A NCOS 0 RTMB 13 21 B-CHANNEL SIGNALING TGAR 0 AST NO IAPG 0 CLS UNR DTN CND WTA LPR APN THFD XREP BARD CLID P10 VNL TKID DATE 9 FEB 2006
TN 003 22 TYPE TIE CDEN SD CUST 0 TRK PRI2 PDCA 1 PCML A NCOS 0 RTMB 13 22 B-CHANNEL SIGNALING TGAR 0 AST NO IAPG 0 CLS UNR DTN CND WTA LPR APN THFD XREP BARD CLID P10 VNL TKID DATE 9 FEB 2006
TN 003 23 TYPE TIE CDEN SD CUST 0 TRK PRI2 PDCA 1 PCML A NCOS 0 RTMB 13 23 B-CHANNEL SIGNALING TGAR 0 AST NO IAPG 0 CLS UNR DTN CND WTA LPR APN THFD XREP BARD CLID P10 VNL TKID DATE 9 FEB 2006
TN 003 24 TYPE TIE CDEN SD CUST 0 TRK PRI2 PDCA 1 PCML A NCOS 0 RTMB 13 24 B-CHANNEL SIGNALING TGAR 0 AST NO IAPG 0 CLS UNR DTN CND WTA LPR APN THFD XREP BARD CLID P10 VNL TKID DATE 9 FEB 2006
TN 003 25 TYPE TIE CDEN SD CUST 0 TRK PRI2 PDCA 1 PCML A NCOS 0 RTMB 13 25 B-CHANNEL SIGNALING TGAR 0 AST NO IAPG 0 CLS UNR DTN CND WTA LPR APN THFD XREP BARD CLID P10 VNL TKID DTC001 0
DATE 9 FEB 2006
TN 003 26 TYPE TIE CDEN SD CUST 0 TRK PRI2 PDCA 1 PCML A NCOS 0 RTMB 13 26 B-CHANNEL SIGNALING TGAR 0 AST NO IAPG 0 CLS UNR DTN CND WTA LPR APN THFD XREP BARD CLID P10 VNL TKID DATE 9 FEB 2006
TN 003 27 TYPE TIE CDEN SD CUST 0 TRK PRI2 PDCA 1 PCML A NCOS 0 RTMB 13 27 B-CHANNEL SIGNALING TGAR 0 AST NO IAPG 0 CLS UNR DTN CND WTA LPR APN THFD XREP BARD CLID P10 VNL TKID DATE 9 FEB 2006
TN 003 28 TYPE TIE CDEN SD CUST 0 TRK PRI2 PDCA 1 PCML A NCOS 0 RTMB 13 28 B-CHANNEL SIGNALING TGAR 0 AST NO IAPG 0 CLS UNR DTN CND WTA LPR APN THFD XREP BARD CLID P10 VNL TKID DATE 9 FEB 2006
TN 003 29 TYPE TIE CDEN SD CUST 0 TRK PRI2 PDCA 1 PCML A NCOS 0 RTMB 13 29 B-CHANNEL SIGNALING TGAR 0 AST NO IAPG 0 CLS UNR DTN CND WTA LPR APN THFD XREP BARD CLID P10 VNL TKID DATE 9 FEB 2006
TN 003 30 TYPE TIE CDEN SD CUST 0 TRK PRI2 PDCA 1 PCML A NCOS 0 RTMB 13 30 B-CHANNEL SIGNALING TGAR 0 AST NO IAPG 0 CLS UNR DTN CND WTA LPR APN THFD XREP BARD CLID P10 VNL TKID DATE 9 FEB 2006
NACT DTC103 0
DCH: 13 MAINT INDICATION TIME: 7:12:30 COUNTER VALUE 16 255
ADAN HIST SIZE 20000 USER MTC BUG ADAN TTY 0 TTY_TYPE SDI CAB 00 CARD 00 PORT 0 DES Remote_Modem FLOW NO USER BUG TTYLOG 0 ADAN TTY 1 TTY_TYPE SDI CAB 00 CARD 00 PORT 1 DES Maintenance BPS 1200 BITL 8 STOP 1 PARY NONE FLOW NO USER MTC BUG TTYLOG 0 BANR YES ADAN TTY 2 TTY_TYPE SDI CAB 00 CARD 00 PORT 2 DES Call_Billing BPS 9600 BITL 7 STOP 1 PARY EVEN FLOW NO USER CTY ADAN TTY 3 TTY_TYPE SDI CAB 01 FIBR DES Maintenance FLOW NO USER MTC TTYLOG 0 BANR YES ADAN TTY 8 TTY_TYPE LSL CAB 00 CARD 10 PORT 0 DES BPS 1200 BITL 8 STOP 1 PARY NONE FLOWTYPE MAIL ADAN AML 9 CARD 10 PORT 1
PAGE 001
DES BPS 4800 CLOK EXT IADR 003 RADR 001 T1 10 T2 002 T3 040 N1 128 N2 08 K 7 RXMT 05 CRC 10 ORUR 005 ABOR 005 ENL NO ADAN DCH 13 CTYP MSDL CARD 03 PORT 1 DES KL_LUT_IP USR PRI DCHL 3 OTBF 32 PARM RS422 DTE DRAT 64KC CLOK EXT IFC ESGF PINX_CUST 0 ISDN_MCNT 300 CLID OPT0 CO_TYPE STD SIDE NET CNEG 1 RLS ID ** QCHID YES RCAP COLP MBGA NO OVLR NO OVLS NO T310 120 T200 3 T203 10 N200 3 N201 260 K 7 ADAN DCH 19 CTYP MSDL CARD 09 PORT 1 DES Telecom_ISDN USR PRI DCHL 9 0 OTBF 32 PARM RS422 DTE DRAT 64KC CLOK EXT IFC APAC CNTY MSIA ISDN_MCNT 300 CLID OPT4
PAGE 002
PROG NCHG CO_TYPE STD SIDE USR CNEG 1 RLS ID ** RCAP BRI MBGA NO OVLR NO OVLS NO T310 10 INC_T306 2 OUT_T306 30 T200 3 T203 10 N200 3 N201 260 K 7
REQ prt TYPE adan dch
ADAN DCH 13 CTYP MSDL CARD 03 PORT 1 DES KL_LUT_IP USR PRI DCHL 3 OTBF 32 PARM RS422 DTE DRAT 64KC CLOK EXT IFC ESGF PINX_CUST 0 ISDN_MCNT 300 CLID OPT0 CO_TYPE STD SIDE NET CNEG 1 RLS ID ** QCHID YES RCAP COLP MBGA NO OVLR NO OVLS NO T310 120 T200 3 T203 10 N200 3 N201 260 K 7 ADAN DCH 19 CTYP MSDL CARD 09 PORT 1 DES Telecom_ISDN USR PRI DCHL 9 0 OTBF 32 PARM RS422 DTE DRAT 64KC CLOK EXT IFC APAC CNTY MSIA ISDN_MCNT 300 CLID OPT4 PROG NCHG CO_TYPE STD SIDE USR CNEG 1 RLS ID ** RCAP BRI MBGA NO OVLR NO OVLS NO T310 10 INC_T306 2 OUT_T306 30 T200 3 T203 10 N200 3
PAGE 001
N201 260 K 7
REQ **** OVL000
PT1000
REQ: prt TYPE: rdb CUST 0 ROUT ACOD
TYPE RDB CUST 00 DMOD ROUT 0 DES BOTHWAYS_TRUNK TKTP COT NPID_TBL_NUM 0 PRIV NO RPA NO SAT NO RCLS EXT DTRK NO ISDN NO PTYP ACO AUTO NO ICOG IAO RANX NO SRCH RRB TRMB YES STEP ACOD 6100 TARG BILN NO OABS TIMR ICF 512 OGF 512 EOD 4096 DSI 34944 NRD 10112 DDL 70 ODT 4096 RGV 256 FLH 510 GTO 896 GTI 896 ARP 3 SFB 3 CRD 512 IENB 5 TFD 0 LEXT 100 VGD 6 SST 3 0 DTD NO SCDT NO
2 DT NO NEDC ETH FEDC ETH CPDC NO SPCT IMM HOLD 02 02 40 SEIZ 02 02 RGFL 02 02 RVSD 08 31 ILLR 02 02 DDO NO DRNG YES NDRI 00 CDR YES INC NO LAST NO QREC NO OAL YES
PAGE 002
AIA NO OAN NO OPD NO NDP EXC 0 CDRX NO CCO NO NATL YES SSL CFWR NO IDOP NO MUS NO MR NO PANS YES MANO NO EQAR YES NTOL DENY ITOL DENY FRL 0 0 FRL 1 1 FRL 2 2 FRL 3 3 FRL 4 4 FRL 5 5 FRL 6 6 FRL 7 7 OHQ NO OHQT 00 TTBL 0 OHTD NO PLEV 2 OPR NO RCAL NO MCTS NO ALRM NO ART 0 PECL NO DCTI 0 TIDY 9 0 SGRP 0 AACR NO
TYPE RDB CUST 00 DMOD ROUT 1 DES TKTP COT NPID_TBL_NUM 0 PRIV NO RPA NO SAT NO RCLS EXT DTRK NO ISDN NO PTYP ACO AUTO NO ICOG IAO RANX NO SRCH RRB TRMB YES STEP ACOD 6101 TARG
2 DT NO NEDC ETH FEDC ETH CPDC NO SPCT IMM HOLD 02 02 40 SEIZ 02 02 RGFL 02 02 RVSD 08 31 ILLR 02 02 DDO NO DRNG YES NDRI 00 CDR YES INC NO LAST NO QREC NO OAL YES AIA NO OAN YES OPA YES OPD YES NDP EXC 0 CDRX NO CCO NO NATL YES SSL CFWR NO IDOP NO MUS NO MR NO PANS YES MANO NO EQAR NO FRL 0 5 FRL 1 5 FRL 2 5 FRL 3 5 FRL 4 5
PAGE 004
FRL 5 5 FRL 6 5 FRL 7 5 OHQ NO OHQT 00 TTBL 0 OHTD NO PLEV 2 OPR NO RCAL NO MCTS NO ALRM NO ART 0 PECL NO DCTI 0 TIDY 7701 1 SGRP 0 AACR NO
TYPE RDB CUST 00 DMOD ROUT 3 DES TKTP TIE NPID_TBL_NUM 0 ESN NO RPA NO CNVT NO SAT NO RCLS EXT DTRK NO ISDN NO PTYP ATT AUTO NO DNIS NO ICOG IAO SRCH LIN TRMB YES STEP ACOD 6103 TARG BILN NO OABS INST IDC NO DCNO 0 * NDNO 0 DEXT NO ANTK SIGO STD STYP SDAT MFC NO TIMR ICF 512 OGF 512 EOD 13952 DSI 34944 NRD 10112 DDL 70 ODT 4096 RGV 640 GTO 896 GTI 896
PAGE 005
SFB 3 IENB 5 TFD 0 VSS 0 VGD 6 EESD 1024 SST 5 0 DTD NO SCDT NO
2 DT NO NEDC ETH FEDC ETH CPDC NO DLTN YES HOLD 02 02 40 SEIZ 02 02 SVFL 02 02 DRNG NO CDR NO NATL YES SSL CFWR NO IDOP NO VRAT NO MUS NO PANS YES MANO NO FRL 0 0 FRL 1 0 FRL 2 0 FRL 3 0 FRL 4 0 FRL 5 0 FRL 6 0 FRL 7 0 OHQ NO OHQT 00 CBQ NO AUTH NO TTBL 0 OHTD NO PLEV 2 OPR NO ALRM NO ART 0 PECL NO DCTI 0 TIDY 7703 3 ATRR NO TRRL NO SGRP 0 AACR NO
TYPE RDB CUST 00 DMOD ROUT 6 DES 03-216087XX TKTP DID TW_ROUTE NO NPID_TBL_NUM 0 SAT NO RCLS EXT
PAGE 006
DTRK NO ISDN NO PTYP ACO AUTO NO DNIS NO ICOG ICT STEP ACOD 6106 TARG BILN NO OABS INST IDC YES DCNO 0 NDNO 0 * DEXT NO DNAM NO MFC R2MF INDMF NO MFCI 2 R2MD NO SGL NO BSSU NO OPP NORM SWP NORM ICIS YES ICNP UKWN ICNT UKWN ICPS YES TIMR MFC 12032 MFO 0 MFID 0 ICF 512 OGF 512 EOD 13952 DSI 4992 NRD 10112 DDL 70 ODT 4096 RGV 256 FLH 510 GTO 896 GTI 896 SFB 3 IENB 5 TFD 0 VSS 0 VGD 6 SST 5 0 SCDT NO
2 DT NO NEDC ETH FEDC ETH CPDC NO DLTN NO HOLD 02 02 40 SEIZ 02 02 SVFL 02 02 OPCB NO DRNG YES NDRI 00 CDR YES
PAGE 007
INC YES LAST NO QREC NO OAL YES AIA NO OAN YES OPA YES OPD NO NDP EXC 0 CDRX NO CCO NO NATL YES CFWR NO IDOP NO VRAT NO MUS NO PANS YES FRL 0 0 FRL 1 0 FRL 2 0 FRL 3 0 FRL 4 0 FRL 5 0 FRL 6 0 FRL 7 0 OHQ NO OHQT 00 TTBL 0 PNNC NO OHTD NO PLEV 2 OPR NO EOS NO RCAL NO MCTS NO ALRM NO BTT 30 NCNI 0 CNIE NO CNIT NO CTAT YES ART 0 PECL NO DCTI 0 TIDY 7706 6 SGRP 0 AACR NO
TYPE RDB CUST 00 DMOD ROUT 8 DES TIE TKTP TIE NPID_TBL_NUM 0 ESN NO RPA NO CNVT NO SAT NO RCLS EXT DTRK YES DGTP DTI2 ISDN NO
PAGE 008
DSEL VOD PTYP DTT AUTO NO DNIS NO ICOG IAO SRCH RRB TRMB YES STEP ACOD 6108 TARG BILN NO OABS INST IDC NO DCNO 0 * NDNO 0 DEXT NO ANTK SIGO STD STYP SDAT MFC NO TIMR ICF 512 OGF 512 EOD 13952 DSI 34944 NRD 10112 DDL 70 ODT 4096 RGV 256 GTO 896 GTI 896 SFB 3 IENB 5 TFD 0 VSS 0 VGD 6 SST 5 0 DTD NO SCDT NO
2 DT NO NEDC ETH FEDC ETH CPDC NO DLTN NO HOLD 02 02 40 SEIZ 02 02 SVFL 02 02 DRNG YES NDRI 00 CDR YES INC YES LAST NO QREC NO OAL YES AIA YES OAN YES OPD NO NDP EXC 0 CDRX NO NATL YES SSL CFWR NO
PAGE 009
IDOP NO VRAT NO MUS NO PANS YES MANO NO FRL 0 0 FRL 1 1 FRL 2 2 FRL 3 3 FRL 4 4 FRL 5 5 FRL 6 6 FRL 7 0 OHQ NO OHQT 00 CBQ NO AUTH NO TTBL 0 OHTD NO PLEV 2 OPR NO ALRM NO ART 0 OPDL 0 PECL NO DCTI 0 TIDY 21 8 NADT 0 SGRP 0 AACR NO
TYPE RDB CUST 00 DMOD ROUT 9 DES 21682100 TKTP DID TW_ROUTE NO NPID_TBL_NUM 0 SAT NO RCLS EXT DTRK YES BRIP NO DGTP PRI2 ISDN YES MODE PRA IFC APAC CNTY MSIA SBN NO PNI 00000 NCNA NO NCRD NO ISAR NO CPFXS YES DAPC NO INTC NO DSEL VOD PTYP DCO AUTO NO DNIS NO ICOG IAO RANX NO SRCH RRB
PAGE 010
TRMB YES STEP ACOD 6109 TCPP NO TARG BILN NO OABS INST IDC YES DCNO 0 NDNO 0 * DEXT NO DNAM NO MFC NO ICIS YES OGIS YES PTUT 0 TIMR ICF 512 OGF 512 EOD 4096 NRD 10112 DDL 70 ODT 4096 RGV 256 FLH 510 GTO 896 GTI 896 SFB 3 NBS 2048 NBL 4096 IENB 5 TFD 0 VSS 0 VGD 6 DTD NO SCDT NO
2 DT NO DDO NO DRNG YES NDRI 00 CDR YES INC NO LAST NO QREC NO OAL YES AIA NO OAN YES OPA YES OPD NO NDP EXC 0 CDRX NO CCO NO NATL YES SSL CFWR NO IDOP NO VRAT NO MUS NO PANS YES EQAR NO FRL 0 0 FRL 1 1
PAGE 011
FRL 2 2 FRL 3 3 FRL 4 4 FRL 5 5 FRL 6 6 FRL 7 7 OHQ NO OHQT 00 TTBL 0 PLEV 2 OPR NO PRDL NO EOS NO DNSZ 0 RCAL NO MCTS NO ALRM NO BTT 30 ACKW NO ART 0 PECL NO DCTI 0 TIDY 7109 9 SGRP 0 AACR NO
TYPE RDB CUST 00 DMOD ROUT 10 DES TIE_LINE TKTP TIE NPID_TBL_NUM 0 ESN YES RPA NO CNVT NO SAT NO RCLS EXT DTRK NO ISDN NO PTYP ATT AUTO NO DNIS NO ICOG IAO SRCH RRB TRMB YES STEP ACOD 6110 TARG BILN NO OABS INST IDC NO DCNO 0 * NDNO 0 DEXT NO ANTK SIGO STD STYP SDAT MFC NO TIMR ICF 512 OGF 512 EOD 13952
2 DT NO NEDC ETH FEDC ETH CPDC NO DLTN YES HOLD 02 02 40 SEIZ 02 02 SVFL 02 02 DRNG YES NDRI 00 CDR NO NATL YES SSL CFWR NO IDOP NO VRAT NO MUS NO PANS YES MANO NO FRL 0 6 FRL 1 6 FRL 2 6 FRL 3 6 FRL 4 6 FRL 5 6 FRL 6 6 FRL 7 7 OHQ NO OHQT 00 CBQ NO AUTH NO TTBL 0 OHTD NO PLEV 2 OPR NO ALRM NO ART 0 PECL NO DCTI 0 TIDY 8 10 ATRR NO TRRL NO SGRP 0 AACR NO
TYPE RDB
PAGE 013
CUST 00 DMOD ROUT 13 DES KL_LUT_IP TKTP TIE NPID_TBL_NUM 0 ESN NO RPA NO CNVT NO SAT NO RCLS EXT DTRK YES BRIP NO DGTP PRI2 ISDN YES MODE PRA IFC ESGF SBN NO PNI 00001 NCNA NO NCRD NO CTYP UKWN INAC NO ISAR NO CPFXS YES DAPC NO INTC NO DSEL VOD PTYP DTT AUTO NO DNIS NO ICOG IAO SRCH LIN TRMB YES STEP ACOD 6113 TCPP NO TARG BILN NO OABS INST IDC NO DCNO 0 * NDNO 0 DEXT NO ANTK SIGO STD MFC NO ICIS YES OGIS YES PTUT 0 TIMR ICF 512 OGF 512 EOD 4096 NRD 10112 DDL 70 ODT 4096 RGV 256 GTO 896 GTI 896 SFB 3 NBS 2048 NBL 4096
PAGE 014
2 DT NO DRNG YES NDRI 00 CDR NO NATL YES SSL CFWR NO IDOP NO VRAT NO MUS NO PANS YES FRL 0 0 FRL 1 1 FRL 2 2 FRL 3 3 FRL 4 4 FRL 5 5 FRL 6 6 FRL 7 7 OHQ NO OHQT 00 CBQ NO AUTH NO TTBL 0 PLEV 2 OPR NO ALRM NO ART 0 PECL NO DCTI 0 TIDY 6113 13 SGRP 0 AACR NO
TYPE RDB CUST 00 DMOD ROUT 18 DES TKTP TIE NPID_TBL_NUM 0 ESN NO RPA NO CNVT NO SAT NO RCLS EXT DTRK YES DGTP DTI2 ISDN NO DSEL VOD PTYP DTT AUTO NO DNIS NO ICOG IAO SRCH RRB TRMB YES STEP
PAGE 015
ACOD 6118 TARG BILN NO OABS INST IDC NO DCNO 0 * NDNO 0 DEXT NO ANTK SIGO STD STYP SDAT MFC R2MF INDMF NO MFCI 2 R2MD NO SGL NO BSSU NO OPP NORM SWP NORM ICIS YES ICNP UKWN ICNT UKWN ICPS YES TIMR MFC 12032 MFO 0 MFID 0 ICF 512 OGF 512 EOD 13952 DSI 34944 NRD 10112 DDL 70 ODT 4096 RGV 256 GTO 896 GTI 896 SFB 3 IENB 5 TFD 0 VSS 0 VGD 6 SST 5 0 DTD NO SCDT NO
2 DT NO NEDC ETH FEDC ETH CPDC NO DLTN NO HOLD 02 02 40 SEIZ 02 02 SVFL 02 02 DRNG NO CDR NO NATL YES SSL CFWR NO IDOP NO VRAT NO MUS NO PANS YES
PAGE 016
MANO NO FRL 0 0 FRL 1 1 FRL 2 2 FRL 3 3 FRL 4 4 FRL 5 5 FRL 6 6 FRL 7 7 OHQ NO OHQT 00 CBQ NO AUTH NO TTBL 0 PNNC NO OHTD NO PLEV 2 OPR NO ALRM NO NCNI 0 CNIE NO CNIT NO CTAT YES ART 0 OPDL 0 PECL NO DCTI 0 TIDY 6118 18 NADT 0 SGRP 0 AACR NO
TYPE RDB CUST 00 DMOD ROUT 20 DES TKTP COT NPID_TBL_NUM 0 PRIV NO RPA NO SAT NO RCLS EXT DTRK NO ISDN NO PTYP ACO AUTO YES ACMP NO ICOG IAO RANX NO SRCH LIN TRMB YES STEP ACOD 6120 TARG BILN NO OABS TIMR ICF 512 OGF 512 EOD 4096 DSI 4992 NRD 1920 DDL 70
2 DT NO NEDC ETH FEDC ETH CPDC NO SPCT IMM HOLD 02 02 40 SEIZ 02 02 RGFL 02 02 RVSD 08 31 ILLR 02 02 DDO NO DRNG YES NDRI 00 CDR YES INC NO LAST NO QREC NO OAL YES AIA NO OAN NO OPD NO NDP EXC 0 CDRX NO CCO NO NATL YES SSL CFWR NO IDOP NO MUS NO MR NO PANS YES MANO NO EQAR NO FRL 0 0 FRL 1 1 FRL 2 2 FRL 3 3 FRL 4 4 FRL 5 5 FRL 6 6 FRL 7 0 OHQ NO OHQT 00 TTBL 0 OHTD NO PLEV 2 OPR NO
PAGE 018
RCAL NO MCTS NO ALRM NO ART 0 PECL NO DCTI 0 TIDY 7720 20 SGRP 0 AACR NO
REQ: **** OVL000
PT0000 REQ: prt TYPE: tnb TN 3 CUST DATE PAGE DES
TN 003 25 TYPE TIE CDEN SD CUST 0 TRK PRI2 PDCA 1 PCML A NCOS 0 RTMB 13 25 B-CHANNEL SIGNALING TGAR 0 AST NO IAPG 0 CLS UNR DTN CND WTA LPR APN THFD XREP BARD CLID P10 VNL TKID DATE 9 FEB 2006
PT2000
REQ iss
MAIN CAB VERSION 2111 RELEASE 25 ISSUE 30 PSWV VERSION: PSWV 54
3 x PVDM-12 installed on each router - at 4 channels per dsp. This equals a total of 12 channels per PVDM-12, thus 36 channels in total. The default 'codec complexity medium' in voice-card 1.
------------------ show version ------------------
Cisco IOS Software, C2600 Software (C2600-IPVOICEK9-M), Version
12.4(1c), RELEAS E SOFTWARE (fc1) Technical Support:
(c) 1986-2005 by Cisco Systems, Inc. Compiled Tue 25-Oct-05 20:55 by evmiller
ROM: System Bootstrap, Version 12.2(8r) [cmong 8r], RELEASE SOFTWARE (fc1)
KLCC-GW uptime is 5 days, 21 hours, 48 minutes System returned to ROM by power-on System image file is "flash:c2600-ipvoicek9-mz.124-1c.bin"
This product contains cryptographic features and is subject to United States and local country laws governing import, export, transfer and use. Delivery of Cisco cryptographic products does not imply third-party authority to import, export, distribute or use encryption. Importers, exporters, distributors and users are responsible for compliance with U.S. and local country laws. By using this product you agree to comply with applicable laws and regulations. If you are unable to comply with U.S. and local laws, return this product immediately.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
If you require further assistance please contact us by sending email to snipped-for-privacy@cisco.com.
Cisco 2651XM (MPC860P) processor (revision 0x401) with 253952K/8192K bytes of me mory. Processor board ID FHK00000000 (0000000000) M860 processor: part number 5, mask 2
2 FastEthernet interfaces
31 Serial interfaces
2 Serial(sync/async) interfaces
1 Channelized E1/PRI port
32K bytes of NVRAM.
32768K bytes of processor board System flash (Read/Write)
VIC Slot 0: E1 (1 Port) Multi-Flex Trunk WAN Daughter Card Hardware revision 1.0 Board revision F0 Serial number 32741293 Part number 800-04475-03 Test history 0x0 RMA number 00-00-00
Currently, both routers have been upgraded to use c2600-ipvoicek9-mz.124-10.bin Also, changing the ascending and descending order, doesn't help.
M
MdV
To solved this problem, we need to configure voice-card to use 'codec complexity high'. This will match both of the configurations.
Having that, to use 30 channels, you need to make sure you have 5 sticks of PVDM-12=. This will get you the total of 15 DSPs, and 30 channels available.
Read the doc here:
M
MdV
This is the final configurations:
SITE A:
! version 12.4 service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption ! hostname KLCC-GW ! boot-start-marker boot-end-marker ! logging buffered 4096 debugging enable password cisco ! no aaa new-model clock timezone MY 8 no network-clock-participate slot 1 no network-clock-participate wic 0 voice-card 1 codec complexity high ! ip cef ! ! ! ! isdn switch-type primary-qsig ! ! voice call send-alert voice rtp send-recv ! ! ! ! ! ! ! ! ! ! ! ! ! ! controller E1 1/0 pri-group timeslots 1-31 description Connection to KLCC PBX ! ! ! interface FastEthernet0/0 no ip address shutdown duplex auto speed auto ! interface Serial0/0 bandwidth 1024 ip address 144.199.160.1 255.255.255.252 no fair-queue ip rtp header-compression ! interface FastEthernet0/1 no ip address shutdown duplex auto speed auto ! interface Serial0/1 no ip address shutdown ! interface Serial1/0:15 no ip address encapsulation hdlc isdn switch-type primary-qsig isdn overlap-receiving isdn incoming-voice voice isdn bchan-number-order ascending no cdp enable ! ip route 0.0.0.0 0.0.0.0 144.199.160.2 ! ip http server no ip http secure-server ! ! ! control-plane ! ! ! voice-port 1/0:15 ! ! ! ! ! dial-peer voice 88 voip destination-pattern .T progress_ind setup enable 3 session target ipv4:144.199.160.2 tech-prefix 88 dtmf-relay h245-alphanumeric ! dial-peer voice 99 pots destination-pattern 99T progress_ind alert enable 8 direct-inward-dial port 1/0:15 ! ! line con 0 line aux 0 password cisco login modem InOut transport input all speed 115200 flowcontrol hardware line vty 0 4 password cisco login ! ! end
SITE B:
! version 12.4 service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption ! hostname LUTONG-GW ! boot-start-marker boot-end-marker ! logging buffered 4096 debugging enable password cisco ! no aaa new-model clock timezone MY 8 no network-clock-participate slot 1 no network-clock-participate wic 0 voice-card 1 codec complexity high ! ip cef ! ! ! ! isdn switch-type primary-qsig ! ! voice call send-alert voice rtp send-recv ! ! ! ! ! ! ! ! ! ! ! ! ! ! controller E1 1/0 pri-group timeslots 1-31 description Connection to LUTONG PBX ! ! ! interface FastEthernet0/0 no ip address shutdown duplex auto speed auto ! interface Serial0/0 bandwidth 1024 ip address 144.199.160.2 255.255.255.252 no fair-queue ip rtp header-compression ! interface FastEthernet0/1 no ip address shutdown duplex auto speed auto ! interface Serial0/1 no ip address shutdown ! interface Serial1/0:15 no ip address encapsulation hdlc isdn switch-type primary-qsig isdn overlap-receiving isdn incoming-voice voice isdn bchan-number-order ascending no cdp enable ! ip route 0.0.0.0 0.0.0.0 144.199.160.1 ! ip http server no ip http secure-server ! ! ! control-plane ! ! ! voice-port 1/0:15 ! ! ! ! ! dial-peer voice 99 voip destination-pattern .T progress_ind setup enable 3 session target ipv4:144.199.160.1 tech-prefix 99 dtmf-relay h245-alphanumeric ! dial-peer voice 88 pots destination-pattern 88T progress_ind alert enable 8 direct-inward-dial port 1/0:15 ! ! line con 0 line aux 0 line vty 0 4 password cisco login ! ! end
Report Content
ASAP.
