3640 won't recognize wic-1shdsl-v2
Sep 23, 2006 2 Replies
Hi!
I've installed a WIC-1SHDSL-V2 in a 3640 as per
ROM: System Bootstrap, Version 11.1(20)AA2, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1) ROM: 3600 Software (C3640-IO3-M), Version 12.3(17a), RELEASE SOFTWARE (fc2)
System image file is "flash:c3640-io3-mz.123-17a.bin" cisco 3640 (R4700) processor (revision 0x00) with 53248K/12288K bytes of memory
the new wic doesn't show up in show interfaces
while show diag reports it as uknown WAN card
Slot 2: Combo 1E, 1R, 2W Port adapter, 4 ports Port adapter is analyzed Port adapter insertion time unknown EEPROM contents at hardware discovery: Hardware revision 1.0 Board revision C0 Serial number 11421513 Part number 800-01223-03 FRU Part Number: NM-1E1R2W=
Test history 0x0 RMA number 00-00-00 EEPROM format version 1 EEPROM contents (hex): 0x00: 01 1F 01 00 00 AE 47 49 50 04 C7 03 00 00 00 00 0x10: 60 00 00 00 98 12 29 17 FF FF FF FF FF FF FF FF
WIC Slot 1: Unknown WAN daughter card Hardware Revision : 0.0 Top Assy. Part Number : 800-23445-02 Board Revision : B0 Deviation Number : 0 Fab Version : 04 PCB Serial Number : FOC09244KSH RMA Test History : 00 RMA Number : 0-0-0-0 RMA History : 00 Version Identifier (VID) : V02 Product (FRU) Number : WIC-1SHDSL-V2 EEPROM format version 4 EEPROM contents (hex): 0x00: 04 FF 40 04 31 41 00 00 C0 46 03 20 00 5B 95 02 0x10: 42 42 30 88 00 00 00 00 02 04 C1 8B 46 4F 43 30 0x20: 39 32 34 34 4B 53 48 03 00 81 00 00 00 00 04 00 0x30: 89 56 30 32 20 CB 8D 57 49 43 2D 31 53 48 44 53 0x40: 4C 2D 56 32 FF FF FF FF FF FF FF FF FF FF FF FF 0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF 49 9E
ideas?
TIA
/CM
The docs don't say the 3640 is supported for the WIC-1SHDSL-V2.
Just the 3631, and 37xx and 38xx platforms are listed.
Cisco seems to have started falling off old hardware for new product support. Ie. the 26xx (non-XM) don't support WIC-1DSU-T1-V2 cards either.
I'd suggest trying a WIC-1SDSHL (non V2 or V3 product), or upgrade the chassis to something more modern.
I know the 3640 is quite a capable chassis still, but cisco's done 3-4 new revs of the thing since, and old gear starts getting not the latest features :(
Thanks for the link, Doug. Sometimes it is not easy to find the right docs in the cisco site. This also explains why my 1720 acts more or less like the 3640.
/CM
