Cisco 1711 VPN hardware module support for AES ???
Mar 17, 2005 7 Replies
stephen
had a similar issue with 1760 (which uses the same VPN accelerators i think) - the feature navigator only has 1 AES enabled encryption accelerator, and that only supports 1841 / 26xx / 28xx / 38xx boxes. when we asked cisco around a year back about AES and 1760 they would not…
Cisco 1711 VPN hardware module support for AES ??? open original image
Trying to enable AES encryption on a Cisco 1711 router running IOS
12.3(11)T3 which has a VPN hardwre module.
The following message does not look promising:
crypto isakmp policy 10 encr aes ! Policy disabled because algorithm not supported by encryption hardware authentication pre-share group 2 lifetime 120
#sh ver | inc IOS Cisco IOS Software, C1700 Software (C1700-ADVSECURITYK9-M), Version
12.3(11)T3, RELEASE SOFTWARE (fc4)
#sh diag ...
Slot 3: Virtual Private Network (VPN) Module Port adapter, 1 port Port adapter is analyzed Port adapter insertion time unknown EEPROM contents at hardware discovery: Hardware Revision : 2.1 Part Number : 73-4586-02 Board Revision : C0 Deviation Number : 0-0 Fab Version : 03 PCB Serial Number : FOC084834QY RMA Test History : 00 RMA Number : 0-0-0-0 RMA History : 00 Product (FRU) Number : MOD1700-VPN= EEPROM format version 4 EEPROM contents (hex): 0x00: 04 FF 40 01 79 41 02 01 82 49 11 EA 02 42 43 30 0x10: 80 00 00 00 00 02 03 C1 8B 46 4F 43 30 38 34 38 0x20: 33 34 51 59 03 00 81 00 00 00 00 04 00 FF FF FF 0x30: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Anyone using AES on a Cisco 1710 ?
when we asked cisco around a year back about AES and 1760 they would not make any committments about hardware to support this.
if you can swap hardware you might want to look at 1841 instead - i think that also has AES support for the onboard encryption chip, so you may not need an AIM depending on the throughput you need.
I can get AES to run on two 1841 and a 2811, but no joy with the 1711
~ I can get AES to run on two 1841 and a 2811, but no joy with the 1711
There is no hardware support for AES on the 1700s, but AES in SW has been tested and should work OK. Expect pps performance in the 3-figures range. In fact you can see an example that was done with 1721s at
Cheers,
Aaron
Does that mean that I have to remove the VPN module from the 1711 in order to use AES software-base encyption ???
Or is there anyway to disable the 1711 VPN hardware encyption via IOS configuration ???
Disabling Hardware Encryption
If your Cisco 1700 series router is equipped with an optional Virtual Private Network (VPN) module, it provides hardware 3DES encryption by default. If you wish, you can disable the VPN module and use Cisco IOS software encryption/decryption instead.
The command that disables the VPN module is as follows:
no crypto engine accelerator
The command is executed in configuration mode. The following is an example of its use:
Router(config)#no crypto engine accelerator Warning! all current connections will be torn down. Do you want to continue? [yes/no]: yes . Crypto accelerator in slot 0 disabled . switching to IPsec crypto engine
After this command is executed, the following procedure must be performed to bring up all encryption tunnels appropriately.
Merv wrote: [snip]
[snip]
Watch your CPU as IPSec takes a toll on the router w/o the AIM card. also, reboot it a few times to make sure the above command doesn't disappear dynamically (due to a bug)
