IOS Problem for 3640 with WIC-1T and VWIC-1MFT-G703 in NM-2FE-2W
Nov 12, 2005 9 Replies
Jump to replies (9)
IOS Problem for 3640 with WIC-1T and VWIC-1MFT-G703 in NM-2FE-2W open original image
We currently have a 3640 router with 2 x NM-2FE-2W's installed.
We already have a WIC-1T in the first Slot 0 NM-2FE-2W
The IOS which has been working great is c3640-i-mz.123-4.T.bin
We have added in a VWIC-1MFT-G703= (1-Port RJ-48 Multiflex Trunk - G.703) into Slot 1 NM-2FE-2W
The hardware diagnostics sees the card as below, but the IOS does not as we do nto see a Controller E1 interface.
I researched the IOS to use and discovered
1t/121t1/dtg703.htmhttp://www.cisco.com/en/US/products/hw/routers/ps259/products_data_sheet0‘86a0080091b9c.html The first article posted Aug 2000 states to use Install Cisco IOS Software Release 12.1(2)XD or a later release, and the second article posted without date states to use 12.1(1)T
As I am using 123-4.T.bin then 12.1(1)T should work????
I have researched the cisco tools and cannot find a suitable IOS to support this config and I am beginning to wonder if there is one.
Does anyoine use WIC-1T and G703 in an NM-2FE-2W on a 3640 router or suggest how I find the right IOS.
Thanks Gary
show diag Slot 0: NM-2FE2W Port adapter, 2 ports Port adapter is analyzed Port adapter insertion time unknown EEPROM contents at hardware discovery: Hardware Revision : 1.0 Top Assy. Part Number : 800-04797-01 Board Revision : G0 Deviation Number : 0-0 Fab Version : 05 PCB Serial Number : JAD06210Q22 RMA Test History : 00 RMA Number : 0-0-0-0 RMA History : 00 EEPROM format version 4 EEPROM contents (hex):
0x00: 04 FF 40 00 D8 41 01 00 C0 46 03 20 00 12 BD 01
0x10: 42 47 30 80 00 00 00 00 02 05 C1 8B 4A 41 44 30
0x20: 36 32 31 30 51 32 32 03 00 81 00 00 00 00 04 00
0x30: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
WIC Slot 0: Serial 1T WAN daughter card Hardware revision 1.1 Board revision G0 Serial number 13259935 Part number 73-1775-02 Test history 0x0 RMA number 00-00-00 Connector type Wan Module EEPROM format version 1 EEPROM contents (hex):
0x20: 01 02 01 01 00 CA 54 9F 49 06 EF 02 00 00 00 00
0x30: 80 00 00 00 99 03 18 01 FF FF FF FF FF FF FF FF
Slot 1: NM-2FE2W Port adapter, 2 ports Port adapter is analyzed Port adapter insertion time unknown EEPROM contents at hardware discovery: Hardware Revision : 1.0 Top Assy. Part Number : 800-04797-01 Board Revision : G0 Deviation Number : 0-0 Fab Version : 05 PCB Serial Number : JAD06210QAL RMA Test History : 00 RMA Number : 0-0-0-0 RMA History : 00 EEPROM format version 4 EEPROM contents (hex):
0x20: 36 32 31 30 51 41 4C 03 00 81 00 00 00 00 04 00
WIC Slot 0: E1 G.703 (1 port) WAN daughter card Hardware revision 1.0 Board revision C0 Serial number 31143978 Part number 800-06722-02 Test history 0x0 RMA number 00-00-00 Connector type PCI EEPROM format version 1 EEPROM contents (hex):
0x20: 01 2F 01 00 01 DB 38 2A 50 1A 42 02 00 00 00 00
0x30: 60 00 00 00 04 01 08 00 FF FF FF FF FF FF FF FF
show ip int br gives Interface IP-Address OK? Method Status Protocol FastEthernet0/0 12.12.12.2 YES NVRAM up up Serial0/0 unassigned YES NVRAM administratively down down FastEthernet0/1 12.12.20.113 YES NVRAM up up FastEthernet1/0 unassigned YES NVRAM up down FastEthernet1/1 unassigned YES NVRAM up down Loopback0 unassigned YES NVRAM up up
MISSING ANY CONTROLLER FOR THE E1 card.
I think you will find it is there. Take a look at your running config. Does it say
! card type command needed for slot x ?
Note: Configuration of the E1 multiflex trunk ports is not like the T1 CSU/DSU WIC (WIC-1DSU-T1). Configure the E1 multiflex trunk ports as controller e1 slot/port , which is similar to the channelized E1/ISDN PRI network module. It wont work like a normal WIC module. You have to feed the router some commands before it will show up as an interface. There is lots of stuff about VOIP on the cisco website if you enter your card part number in and search configuration on it. Cheers
Matt
No lines like that, and conf t will not accept interface controller e1 etc etc
What IOS commands are you refrring to?
Gary
There was no mention of an IOS on the page I was looking at. Ive got a G.703 DS3 card and by default I have to feed it a few commands before it gives me an interface to use. It seems your IOS is happy with it because its showing up. Normally when the IOS doesnt like it you would see unsupported WIC or the like.
Cheers
Matt
Says a 3640 should support a VWIC-1MFT-G703 in a NM-2FE-2W with IOS
Thanks Gary
show diag Slot 0: NM-2FE2W Port adapter, 2 ports Port adapter is analyzed Port adapter insertion time unknown EEPROM contents at hardware discovery: Hardware Revision : 1.0 Top Assy. Part Number : 800-04797-01 Board Revision : G0 Deviation Number : 0-0 Fab Version : 05 PCB Serial Number : JAD06210Q22 RMA Test History : 00 RMA Number : 0-0-0-0 RMA History : 00 EEPROM format version 4 EEPROM contents (hex): 0x00: 04 FF 40 00 D8 41 01 00 C0 46 03 20 00 12 BD 01 0x10: 42 47 30 80 00 00 00 00 02 05 C1 8B 4A 41 44 30 0x20: 36 32 31 30 51 32 32 03 00 81 00 00 00 00 04 00 0x30: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
WIC Slot 0: Serial 1T WAN daughter card Hardware revision 1.1 Board revision G0 Serial number 13259935 Part number 73-1775-02 Test history 0x0 RMA number 00-00-00 Connector type Wan Module EEPROM format version 1 EEPROM contents (hex): 0x20: 01 02 01 01 00 CA 54 9F 49 06 EF 02 00 00 00 00 0x30: 80 00 00 00 99 03 18 01 FF FF FF FF FF FF FF FF
Slot 1: NM-2FE2W Port adapter, 2 ports Port adapter is analyzed Port adapter insertion time unknown EEPROM contents at hardware discovery: Hardware Revision : 1.0 Top Assy. Part Number : 800-04797-01 Board Revision : G0 Deviation Number : 0-0 Fab Version : 05 PCB Serial Number : JAD06210QAL RMA Test History : 00 RMA Number : 0-0-0-0 RMA History : 00 EEPROM format version 4 EEPROM contents (hex): 0x00: 04 FF 40 00 D8 41 01 00 C0 46 03 20 00 12 BD 01 0x10: 42 47 30 80 00 00 00 00 02 05 C1 8B 4A 41 44 30 0x20: 36 32 31 30 51 41 4C 03 00 81 00 00 00 00 04 00 0x30: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
WIC Slot 0: E1 G.703 (1 port) WAN daughter card Hardware revision 1.0 Board revision C0 Serial number 31143978 Part number 800-06722-02 Test history 0x0 RMA number 00-00-00 Connector type PCI EEPROM format version 1 EEPROM contents (hex): 0x20: 01 2F 01 00 01 DB 38 2A 50 1A 42 02 00 00 00 00 0x30: 60 00 00 00 04 01 08 00 FF FF FF FF FF FF FF FF
Hello Gary,
can you try and use the global command:
card type {t1 | e1} slot [bay]
first, and then try to configure the controller ?
Regards,
Naz
Hello Gary,
Regards,
Naz
Where do I enter that? Under normal enable or in conf t
It is a Cisco 3640 router.
Neither worked or I am doing something silly?
Gary
Hello Gary,
this should be a global command, which you already tried, and apparently the command is not available...:( According to the documentation the VWIC-1MFT-G703 in combination with the NM-2FE2W in the 3640 requires 12.1(1)T or 12.2T. Can you try and load exactly one of those ? Normally you would suppose that higher IOS versions support everything below, but I have seen cases where that does not always work...
Regards,
Naz
Logged a TAC case and it turns out the software advisor is broken.
Cool!
Gary
