error while installing HWIC-1CE1T1-PRI V02 interface card
May 10, 2013 1 Replies
error while installing HWIC-1CE1T1-PRI V02 interface card open original image
Dear Team,
I have Cisco 3845 router with Cisco IOS Software, 3800 Software (C3845-ADVENTERPRISEK9-M), Version 12.4(25d). "flash:c3845-adventerprisek9-mz.124-25d"
I installed HWIC-1CE1T1-PRI V02 interface card, but it showing below error,
WIC Slot 2: Unknown WAN daughter card WIC module not supported/disabled in this slot Hardware Revision : 0.0 Top Assy. Part Number : 800-34375-01 Part Number : 73-13313-01 Board Revision : B0 Deviation Number : 0 Fab Version : 05 PCB Serial Number : FOC17014PKQ RMA Test History : 00 RMA Number : 0-0-0-0 RMA History : 00 Version Identifier : V02 Product (FRU) Number : HWIC-1CE1T1-PRI CLEI Code : COUIAKJCAB EEPROM format version 4 EEPROM contents (hex): 0x00: 04 FF 40 05 29 41 00 00 C0 46 03 20 00 86 47 01 0x10: 82 49 34 01 01 42 42 30 88 00 00 00 00 02 05 C1 0x20: 8B 46 4F 43 31 37 30 31 34 50 4B 51 03 00 81 00 0x30: 00 00 00 04 00 89 56 30 32 20 CB 8F 48 57 49 43 0x40: 2D 31 43 45 31 54 31 2D 50 52 49 C6 8A 43 4F 55 0x50: 49 41 4B 4A 43 41 42 D9 02 40 C1 FF FF FF FF FF 0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Kindly suggest me asap.
Regards,
Sushant Redkar
snipped-for-privacy@gmail.com
For almost every case, this is you are running a version of IOS that isn't new enough for the card.
The datasheet for
(Which I'm not sure if there is a -v02 of the card or not, as it isn't mentioned in the datasheet, if anything a -V02 would require ever newer code) lists the IOS requirements out.
3800 and 3800 series. Minimium IOS release: 12.4(20)T
You are running an older train than this. 12.4(20)T is newer than 12.4(25)d
Read anything T train release 12.x(x)T as "12.x+1(x) beta."
Or since the great renumbering, read 12.4T as 15.0beta.
Run a 12.4T train or 15.1 train on your router instead.
