Setting DSL downstream Speed
May 27, 2006 5 Replies
Jump to replies (5)
Hi all,
I upgraded my DSL to MAX speed (it should be 8 MBit/s) however my bax stable bandwidth has been tested at 2048 Kbit/s. Despite this I understand that the line provider (British Telecom) configures the DSLAM to sync at the maximum speed.
The downstream rate varies between 4200 and 3200 Kbit/s depending on the time of the day and the line noise (I guess).
Now, here is the problem. Often it happens that the Noise margin falls below 0 dB, when this happens the line re-syncronizes at a lower speed, only to re-sync again automatically at a higher speed when the line quality allows it. When this happens, I loose the connection for a few seconds and any TCP connection is lost (annoying).
I would like to set the downstream rate to a lower speed in order not to incur in these re-syncronizations.
How do I do this on a Cisco 3620 + WIC1-DSL without asking the ISP or line provider? Can I limit the downstream DSL to a fixed rate from my end?
Here is my current configuration:
! interface ATM1/0 no ip address no ip redirects no ip proxy-arp ip route-cache flow no atm ilmi-keepalive bundle enable ! dsl operating-mode itu-dmt hold-queue 224 in ! interface ATM1/0.1 point-to-point no ip redirects no ip proxy-arp pvc 0/38 encapsulation aal5mux ppp dialer dialer pool-member 11 ! !
... and an output from "dsl int atm 1/0" (best shown with fixed character set):
---------------------------------------------------------------------------------------------- ATU-R (DS) ATU-C (US) Modem Status: Showtime (DMTDSL_SHOWTIME) DSL Mode: ITU G.992.1 (G.DMT) ITU STD NUM: 0x01 0x1 Vendor ID: 'ALCB' 'ALCB' Vendor Specific: 0x0000 0x0000 Vendor Country: 0x00 0x0F Capacity Used: 100% 88% Noise Margin: 4.0 dB 8.0 dB Output Power: 20.0 dBm 12.0 dBm Attenuation: 44.0 dB 23.0 dB Defect Status: None None Last Fail Code: Error in early non-CRC message or in first CRC-covered message Selftest Result: 0x00 Subfunction: 0x15 Interrupts: 3383 (0 spurious) PHY Access Err: 0 Activations: 100 Init FW: embedded Operation FW: embedded SW Version: 3.8131 FW Version: 0x1A04
Interleave Fast Interleave Fast Speed (kbps): 0 3712 0 448 Reed-Solomon EC: 0 0 0 0 CRC Errors: 0 64 0 0 Header Errors: 0 16 1 0 Bit Errors: 0 0 BER Valid sec: 0 0 BER Invalid sec: 0 0
------------------------------------------------------------------------------------------------------------------ Thank you in advance,
HD
see if your router will accept the dsl linerate command
interface ATM1/0 dsl linerate {kbps | auto }
Configures the DSL line rate:
  • kbps-Line rate (data transfer rate) in kilobits per second. Allowable entries are 72, 136, 200, 264, 392, 520, 776, 1032, 1160,
1544, 2056, and 2312. * auto-The WIC automatically trains for an optimal line rate by negotiating with the far-end DSLAM or WIC.
The default is auto.
Thank you for your reply.
... I am afraid it doesn't. I have a 3620 12.3(19) IP .... ATM which is the latest. 12.4 is not available on a 3620.
Which IOS version support "linerate" would it work on a 3640 with 12.4 ?
Any alternative?
Here it is:
Router#show diag Slot 0: NM-2FE2W Port adapter, 2 ports Port adapter is analyzed Port adapter insertion time unknown EEPROM contents at hardware discovery: Hardware Revision : 1.0 Top Assy. Part Number : 800-04797-01 Board Revision : G0 Deviation Number : 0-0 Fab Version : 05 PCB Serial Number : JAD06420627 RMA Test History : 00 RMA Number : 0-0-0-0 RMA History : 00 Product (FRU) Number : NM-2FE2W= EEPROM format version 4 EEPROM contents (hex): 0x00: 04 FF 40 00 D8 41 01 00 C0 46 03 20 00 12 BD 01 0x10: 42 47 30 80 00 00 00 00 02 05 C1 8B 4A 41 44 30 0x20: 36 34 32 30 36 32 37 03 00 81 00 00 00 00 04 00 0x30: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
WIC Slot 1: DSL SAR (ADSL)
Hardware Revision : 2.3 Part Number : 73-4771-08 Board Revision : B0 Deviation Number : 1-200 Fab Version : 05 PCB Serial Number : FOC071609ZA RMA Test History : 00 RMA Number : 0-0-0-0 RMA History : 00 Product (FRU) Number : PA-1C-P= EEPROM format version 4 EEPROM contents (hex): 0x00: 04 FF 40 00 2E 41 02 03 82 49 12 A3 08 42 42 30 0x10: 80 00 01 00 C8 02 05 C1 8B 46 4F 43 30 37 31 36 0x20: 30 39 5A 41 03 00 81 00 00 00 00 04 00 FF FF FF 0x30: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Slot 1: NM-2FE2W Port adapter, 2 ports Port adapter is analyzed Port adapter insertion time unknown EEPROM contents at hardware discovery: Hardware Revision : 1.0 Top Assy. Part Number : 800-04797-01 Board Revision : G0 Deviation Number : 0-0 Fab Version : 05 PCB Serial Number : JAD070201KZ RMA Test History : 00 RMA Number : 0-0-0-0 RMA History : 00 Product (FRU) Number : NM-2FE2W= EEPROM format version 4 EEPROM contents (hex): 0x00: 04 FF 40 00 D8 41 01 00 C0 46 03 20 00 12 BD 01 0x10: 42 47 30 80 00 00 00 00 02 05 C1 8B 4A 41 44 30 0x20: 37 30 32 30 31 4B 5A 03 00 81 00 00 00 00 04 00 0x30: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Hardware Revision : 2.3 Part Number : 73-4771-09 Board Revision : C0 Deviation Number : 0-0 Fab Version : 05 PCB Serial Number : FOC08241FV9 RMA Test History : 00 RMA Number : 0-0-0-0 RMA History : 00 Product (FRU) Number : PA-1C-P= EEPROM format version 4 EEPROM contents (hex): 0x00: 04 FF 40 00 2E 41 02 03 82 49 12 A3 09 42 43 30 0x10: 80 00 00 00 00 02 05 C1 8B 46 4F 43 30 38 32 34 0x20: 31 46 56 39 03 00 81 00 00 00 00 04 00 FF FF FF 0x30: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Router#
After going over some more documents on CCO, it looks the dsl linerate command was only implmentated on the 800 series router.
