Trouble configuring Cisco 857, many sites not working
Aug 18, 2006 3 Replies
Jump to replies (3)
First off, I'm a newbie to Cisco equipment. I'm a software developer by trade, working from home for my own company. I outgrew the router that my DSL provider gave me (SBC/AT&T) with my static service (5 static IPs) as I need to host some servers onsite and wanted a decent firewall. So, I read reviews online and purchased the Cisco 857.
I set this up yesterday using the wizard/installer that came with it. I have not enabled the firewall, and am currently using NAT across one of the external static IPs. Internally my network is 192.168.1.0/24.
Generally, everything is working, but a few things are not and it's baffling me. AJAX websites (those that communicate back to the server with Javascript) are generally not working. A prominent example is Google's GMail (gmail.google.com). I can login and view my mail, but I can't send or do anything that requires AJAX functionality. In fact, it seems almost as though I can't do an HTTP POST in general across the
857. Very strange.
When I plug in my old router, everything works fine. When I plug in the 857, I have the issues above. Hopefully somebody has some ideas that can send me in the right direction. I am decent with network equipment, and such. Many years ago I did have experience setting up and managing a Cisco 4000 series, but I've forgotten most of what I knew then. Let me know if you have any ideas on what might be wrong, or how I might be able to figure out what is wrong.
To assist responders, suggest you post the router config and the output of show version.
Just maybe, ... been there.
ip inspect some-name http Actually turns on what I think amounts to Java blocking. I don't know what this looks like in the GUI so... try
! = Comment
telnet 192.168.1.x ! Supply user id and password ! If prompt does not end in "#" en supply "enable" password
sh run | inc inspect !< run[space][pipe][space]inc
! make a note of any lines of the form ! ip inspect some-name http
conf t no ip inspect some-name http ! repeat if necessary
end copy run start ! save the config
sh run | inc inspect !< this is like "| grep" in unix
!##################### ! Dump from router ! login as: jim jim@172.17.9.199's password:
temp>en Password: temp#sh run | inc inspect ip inspect name INS.Home cuseeme ip inspect name INS.Home ftp ip inspect name INS.Home h323 ! ip inspect INS.Home out !< this is the inspect being applied to an interface temp#conf t Enter configuration commands, one per line. End with CNTL/Z. temp(config)#no ip inspect name INS.Home cuseeme temp(config)#end temp#sh run | inc inspect ip inspect name INS.Home ftp ip inspect name INS.Home h323 ip inspect INS.Home out temp#copy run temp#copy running-config start temp#copy running-config startup-config Destination filename [startup-config]? Building configuration... [OK] temp# ##### Now unbreak the router:-) temp#conf t Enter configuration commands, one per line. End with CNTL/Z. temp(config)#ip inspect name INS.Home cuseeme temp(config)#^Z ! [Ctrl]Z = end temp#wr ! "write memory" is the original ! name for this operation and still works. Building configuration... [OK] temp-bh#
You may also wish to investigate the Cisco 857 Config Wizard:
Sincerely,
Brad Reese Cisco Technical Forums
