cisco 857 wfq
Sep 30, 2009 0 Replies
This is a post re implementation of QOS on an 857. the equipment is connected to a PPPoA DSL service.
from what i understand, we are limited in this respect but nonetheless the 857 does support WFQ.
the qu. is where we actually use the 'fair-queue' interface configuration. ?
seems from 'show queueing interface Dialer0' WFQ is enabled here but the same output on ATM0 interface we have FIFO queueing.
would it be correct to assume that it should be 'fair-queue' should be applied also to the ATM0 interface (not apparently configurable in the pvc config) ?
