6500 and DOS
Aug 18, 2006 11 Replies
Jump to replies (11)
6500 and DOS open original image
I need to find a way to analyse DoS attacks and see where traffic is coming from and going to or vica-versa. We run Cat 6500's so I need something that will not kill the CPU of the machine which may already be stressed.
Does the 6500 provide any mechanisms for this.
Thanks Gary
Start with Cisco doc
Protecting the Cisco Catalyst 6500 Series Switches Against Denial-Of-Service Attacks
One of the first things I would suggest is that the 6500's be migrated to native IOS mode.
Just need something to show IP being targetted inbound or outbound and by whom?
Gary
Depending on the volume of traffic one thing that can be done is to use the SPAN fetaure to set up a monitoring port for the interface(s) over which the 6500 receives Internet traffic.
Coonect a PC with Etherreal installed and run a capture. Then use the analyse report that show connection endpoints.
You could alos look at enabling NETFLOW accounting whic will show source and destion IP address and port numbers.
NETFLOW osunds good. Is it a big overhead and how do I enable it.
start with
I believe NETFLOW now supports sampling so you can control how much data it collects and thus control the associated overhead ( probably requires a PFC)
Please post show version and show module for the 6500 switch facing the Internet.
It has a Supervisor Engine 720 (Active) WS-SUP720-3BXL, WS-F6K-PFC3BXL, MSFC3 Daughterboard
If you let me have the commands I can test - TIA Gary
excellent !!!
what IOS version ???
Hopefully this will get you started
! Configure NetFlow on 6500
! 1. enable NetFlow on PFC
mls netflow
! 2. config the type flow mask to be used by NetFlow
mls flow ip full
! 3. display NetFlow flowmask configured
sh mls netflow flowmask
current ip flowmask for unicast: full current ipv6 flowmask for unicast: null
! 4. check NetFlow cache aging timers
show mls netflow aging
enable timeout packet threshold ------ ------- ---------------- normal aging true 300 N/A fast aging false 32 100 long aging true 1920 N/A
! 5. display NetFlow accounting infomation for traffic switched by PFC
sh mls netflow ip any
Displaying Netflow entries in Supervisor Earl DstIP SrcIP Prot:SrcPort:DstPort Src i/f :AdjPtr
----------------------------------------------------------------------------- Pkts Bytes Age LastSeen Attributes
5.38.7.11 223.255.254.254 tcp :45736 :telnet :0x0 0 0 314 08:54:44 L3 - Dynamic 5.38.7.11 5.38.0.2 udp :ntp :ntp :0x0 0 0 527 08:54:29 L3 - Dynamic 0.0.0.0 0.0.0.0 0 :0 :0 :0x0 1238 58508 1817 08:54:34 L3 - Dynam
For configuration of NetFlow sampling see :
Worked a treat!
What is the overhead during a DoS
Thanks Gary
For packets forwarded by the PFC-2 and PFC-3, Netflow statistics are
*collected* "in hardware", so enabling Netflow (even without sampling) won't have a negative impact on forwarding performance.
However, table maintenance, i.e. aging out old entries, and possibly exporting them when NDE (Netflow export) is enabled, does use CPU cycles. That is particularily noticeable when there is a high number of flows, as is seen during aggressive port scanning or some kinds of DoS.
PFC (MLS) Netflow table maintenance is mostly done by the Switch Processor on the Supervisor, not by the Route Processor (MSFC). NDE (Netflow export from the PFC) used to load the MSFC somewhat, but since or 12.2SXE (I think), NDE is done entirely by the Switch Processor.
There is an upper limit on the amount of maintenance work for MLS Netflow, because the table is "walked" at a fixed rate (~32K entries every second, I think). Therefore I don't think you need to be worried that a flow-heavy DoS may bring your box down. I think there may be small issues for things like reading interface counters when the Switch Processor is heavily loaded, but everything else should work just fine.
Because the PFC/MLS Netflow table has a fixed size (128K entries on the PFC-2/PFC-3, 256K on the PFC-3BXL), and aging out old entries is done on a fixed schedule, the hardware Netflow table will run full when there are too many flows. This just means that some packets cannot be accounted for in Netflow.
We actually had to upgrade all our MSFC2 boxes to SUP720's because NDE caused the CPUs to spike to 100%. There were no impact to traffic being switched, but core routers running at 100% is never a good thing!
[snip]
