SUP 720 -6513 Card Sync
Jan 18, 2006 4 Replies
Jump to replies (4)
SUP 720 -6513 Card Sync open original image
HI all,
I have a 6513 with a SUP720 card, this card was not new even though we paid for new, never the less, a new card has arrived. Is there any way I can sync the conf fro the card that is in there to the new card. A few cavets. The new card i assume will be running CAtOS where the old card is running IOS, the memory is the same in both. Thanks Jason
Thanks for the reply. I am not sure what i need to transfer to be honest. I am correct in thinking I can just transfer the running config and the IOS binary then set the boot paramater? I just thought i could transfer the whole setup of the first SUP card to the second and then remove the first card. Jay
I think so:
Only one way to find out!!! Jam that son-bitch in there and let us know what happens.
If you want to have redundancy between cards, they should be the same version of a software. It's impossible to have one card in the Hybrid mode, and another in the Native mode.
If you old (original) card has IOS, you should convert the new card to IOS mode too. Here is the document how to convert Sup720 from CatOS to IOS:
Good luck,
Mike
