PEAP and Aironet 12xx
Sep 22, 2006 1 Replies
PEAP and Aironet 12xx open original image
Hi!
As I understand this document
the Aironet 1200 cannot be used with PEAP without installing additional software. Is this true?
If yes, what other strong security mechanisms do you recommend?
Thanks for any input, Christian
~ As I understand this document ~
~ the Aironet 1200 cannot be used with PEAP without installing additional ~ software. ~ Is this true?
Well, yes, you need an external RADIUS server that supports PEAP. The AP's builtin RADIUS server supports LEAP and EAP-FAST.
~ If yes, what other strong security mechanisms do you recommend?
EAP-FAST would meet the need, assuming that you have EAP-FAST supplicants on your clients.
An alternative for very small deployments would be WPA-PSK - this is plenty secure, assuming that you choose a good strong passphrase.
Regards,
Aaron
