Configuration of EAP with ACS 4.0 and Aironet 1230
Aug 29, 2006 1 Replies
Configuration of EAP with ACS 4.0 and Aironet 1230 open original image
Hello,
I am having a major problem trying to implement EAP authentication using ACS 4.0 for the Aironet 1230. Right now I am not sure if the ACS or the AP or even the client PC is configure correctly. Can someone please give me some good link so i can use to help me set this up?
Thank you.
You may wish to investigate Cisco Aironet 1200 Series Access Point Software Configuration Guide for VxWorks:
Enabling EAP in Cisco Secure ACS
Hope this helps.
Brad Reese Cisco IOS Software - Compatible Partner Matrix by Technology
Hendersonville Road, Suite 17 Asheville, North Carolina USA 28803 USA & Canada: 877-549-2680 International: 828-277-7272 Fax: 775-254-3558 AIM: R2MGrant BradReese.Com - Global Cisco Systems Pre-Sales Support
