MAC Address filter issue
Sep 27, 2006 3 Replies
Jump to replies (3)
MAC Address filter issue open original image
I have a Cisco Aironet 1100 access point that has been in use for 16 months now. I have a limited number of wireless connections using this AP so I decided to apply a MAC Address Filter to provide a measure of security.
This filter was set up quite some time ago using the website interface and has not been changed for at least 6 months.
I went to make a change to it yesterday and received the following error message:
"Filter 700 was configured on interface Dot1Radio0 using CLI. It must be cleared via CLI to ensure proper operation of the website interface".
I did not configure nything under CLI because I have only used the website interface for maintenance.
Can anyone tell me why I am getting this message and/or provide the subset of CLI commands that is needed to clear this configuration out... hopefully without loosing the MAC Address list that I have built?
Thanks in advance for any assistance you can provide.
Junior
Hi Junior,
Use the following syntax:
no access-list [list number]
This will disable the access-list (filter)
All IOS comands can be removed from configuration mode by preceeding the command syntax with 'no'
Hope this helps.
Hey Brad, thanks for the reply. I hate to sound like a total ditz but... how do you get into CLI mode? Is it a case of hooking directly into the AP via Ethernet cable and then somehow issuing a command to link into the OS?
I apologize for my lack of knowledge but it was easy enough to use the web interface to set the AP up. I didn't think I'd ever have to get to a command line interface to operate this sucker!
If you know, what do you suppose caused this issue? As I said, I don't even know how to get to the CLI, let alone use it to modify the access list.
Thanks, Herb
wrote:
Hi Herb,
Cisco IOS Software Configuration Guide for Cisco Aironet Access Points,
12.2(11)JA
Accessing the CLI
Using the Command-Line Interface
Configuring Filters
Herb, hope this helps.
Brad Reese Cisco Network Engineer Directory
