HWIC-DSLSAR not working on cisco 2821
Jan 22, 2009 1 Replies
Dear Sir,
I have installed a cisco 2821 router with HWIC-1ADSL. I have configured the same but with no luck. I am providing you with the output of various commands. Please help
Out put of show interface atm 0/0/0 is yourname#show interface atm 0/0/0 ATM0/0/0 is initializing, line protocol is down Hardware is HWIC-DSLSAR (with Alcatel ADSL Module) MTU 4470 bytes, sub MTU 4470, BW 2048 Kbit, DLY 250 usec, reliability 0/255, txload 1/255, rxload 1/255 Encapsulation ATM, loopback not set Encapsulation(s): AAL5 AAL2, PVC mode 23 maximum active VCs, 256 VCs per VP, 0 current VCCs VC Auto Creation Disabled. VC idle disconnect time: 300 seconds Last input never, output never, output hang never Last clearing of "show interface" counters never Input queue: 0/224/0/0 (size/max/drops/flushes); Total output drops:
0 Queueing strategy: Per VC Queueing 5 minute input rate 0 bits/sec, 0 packets/sec 5 minute output rate 0 bits/sec, 0 packets/sec 0 packets input, 0 bytes, 0 no buffer Received 0 broadcasts, 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort 0 packets output, 0 bytes, 0 underruns 0 output errors, 0 collisions, 0 interface resets 0 output buffer failures, 0 output buffers swapped out
-------------------------------------------------------------------------------------------------------------------------------------------- Output of sh diag command yourname#sh diag Slot 0: C2821 Motherboard with 2GE and integrated VPN Port adapter, 2 ports Port adapter is analyzed Port adapter insertion time Onboard VPN : v2.3.3 EEPROM contents at hardware discovery: PCB Serial Number : FOC12336KGP Hardware Revision :
1.0 Top Assy. Part Number :
800-26921-03 Board Revision : A0 Deviation Number :
0 Fab Version :
03 RMA Test History :
00 RMA Number :
0-0-0-0 RMA History :
00 Processor type :
87 Hardware date code Chassis Serial Number : FHK1236F08S Chassis MAC Address :
0023.0440.e920 MAC Address block size :
32 CLEI Code : COM7M00ARA Product (FRU) Number : CISCO2821 Part Number :
73-8853-05 Version Identifier : V04 EEPROM format version 4 EEPROM contents (hex): 0x00: 04 FF C1 8B 46 4F 43 31 32 33 33 36 4B 47 50
40 0x10: 03 E8 41 01 00 C0 46 03 20 00 69 29 03 42 41
30 0x20: 88 00 00 00 00 02 03 03 00 81 00 00 00 00 04
00 0x30: 09 87 83 01 32 68 B7 C2 8B 46 48 4B 31 32 33
36 0x40: 46 30 38 53 C3 06 00 23 04 40 E9 20 43 00 20 C6 0x50: 8A 43 4F 4D 37 4D 30 30 41 52 41 CB 8F 43 49
53 0x60: 43 4F 32 38 32 31 20 20 20 20 20 20 82 49 22
95 0x70: 05 89 56 30 34 20 D9 02 40 C1 FF FF FF FF FF FF
WIC Slot 0: ADSL over ISDN Hardware Revision :
4.0 Top Assy. Part Number :
800-26248-01 Board Revision :
01 Deviation Number :
0 Fab Version :
04 PCB Serial Number : FHH090300JF RMA Test History :
00 RMA Number :
00 Product (FRU) Number : HWIC-1ADSLI Version Identifier : NA EEPROM format version 4 EEPROM contents (hex): 0x00: 04 FF 40 04 C9 41 04 00 C0 46 03 20 00 66 88
01 0x10: 42 30 31 88 00 00 00 00 02 04 C1 8B 46 48 48
30 0x20: 39 30 33 30 30 4A 46 03 00 81 00 00 00 00 04
00 0x30: CB 8B 48 57 49 43 2D 31 41 44 53 4C 49 89 4E
41 0x40: 20 20 D9 02 40 C1 FF FF FF FF FF FF FF FF FF FF 0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
EM Slot 0: ADSL over ISDN non-removable daughtercard Hardware Revision :
4.0 Part Number :
73-9308-04 Board Revision :
0 Fab Version :
04 PCB Serial Number : FHH090300EB RMA Test History :
00 RMA Number :
00 Fab Part Number :
28-6607-04 Manufacturing Test Data : 00 00 00 00 00 00 00
00 Field Diagnostics Data : 00 00 00 00
00 Connector Type :
01 Product (FRU) Number : HWIC-1ADSLI Version Identifier : NA EEPROM format version 4 EEPROM contents (hex): 0x00: 04 FF 40 04 7B 41 04 00 82 49 24 5C 04 42 30
31 0x10: 88 00 00 00 00 02 04 C1 8B 46 48 48 30 39 30
33 0x20: 30 30 45 42 03 00 81 00 00 00 00 04 00 85 1C
19 0x30: CF 04 C4 08 00 00 00 00 00 00 00 00 C5 08 00
00 0x40: 00 00 00 00 00 00 05 01 CB 8B 48 57 49 43 2D
31 0x50: 41 44 53 4C 49 89 4E 41 20 20 FF FF FF FF FF FF 0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
yourname# yourname# yourname# yourname# yourname#sh int atm 0/0/0 ATM0/0/0 is initializing, line protocol is down Hardware is HWIC-DSLSAR (with Alcatel ADSL Module) MTU 4470 bytes, sub MTU 4470, BW 2048 Kbit, DLY 250 usec, reliability 0/255, txload 1/255, rxload
0 Queueing strategy: Per VC Queueing 5 minute input rate 0 bits/sec, 0 packets/ sec 5 minute output rate 0 bits/sec, 0 packets/ sec 0 packets input, 0 bytes, 0 no buffer Received 0 broadcasts, 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort 0 packets output, 0 bytes, 0 underruns 0 output errors, 0 collisions, 0 interface resets 0 output buffer failures, 0 output buffers swapped out
-------------------------------------------------------------------------------------------------------------------------------------------- The output of sh controllers atm
Interface: ATM0/0/0, Hardware: HWIC-DSLSAR (with Alcatel ADSL Module), State: in itializingthe Cisco IDB: 475989B8 Instance: 47599AF8 reg_dslsar:B0120000 adsl_regs: B0160000ecret 0
no us fpgaRegs:B0008000 alcRegs: B0180000ce and with t PHY Inst:475D4650 us_bwidth:2048to use Slot: 0 Unit: 0 Subunit: 0 pkt Size:
4528ion about SDM please follow the instructions in the QUICK START VCperVP: 256 max_vp: 256 max_vc: 65536 total vc:
0UIDE for your router or go to
vpivcibit:16 connTblVCI:8 vpi_bits:
8-------------------------------------------- vpvc_sel:3 enabled: 0 throttled: 0 ss Verification
delayed_tbqe: 00000000 invalid_tbqe_index: 00000000urrent configuration : 2906 bytes
FPGA Register Value Notes service timestamps debug d
--------------- ---------- ---------- service timestamps log datet FPGA Rev 0x00050027 no service p
ADSL Register Value Notes ! hostname yourname
--------------- ---------- ---------- boot-end-marker intr_enable_reg: 0xC1C VCCLOSED.JUMPC.RQAF.RPQAF.TBQAF. ! no aaa new-model ! ! ip cef ADSL Config Reg 0x00098C80 CD LED fast blink; ! multilink bundle-name LT-TE Mode = TE; ! vpdn enable ! vpdn-group pp NTR Pass Thru = 0; protocol pppoe l2tp tunne NTR Enable ! ! voice-card Tx Error: 0x00000000 1 di Lookup Error cnt: 0x00000000ppp authentication chap call Invalid Cell cnt: 0x00000000 ppp chap hostname doea Tx packet: 0x00000000 ppp chap password 0 Tx OAM: 0x00000000 ! router rip Rx packet: 0x00000000twork 172.24.0.0 Rx packet drop: 0x00000000 ! ip Rx OAM: 0x00000000161.190 Rx OAM drop: 0x00000000.0.0.0 0.0.0.0 GigabitEthern Timer: 0x00000000 ip route tstBase1: 0x0001B71 JMP-COMPLETE:0x1 vel FIFOF: 0x1ase change these publ FBQE: 0x1dentials using SDM or Last Addr:0x0
Host Memory Qs Value Notes
Here are the Cis
username privilege rxCellQ: 0x0F64E000 rxPacketQ: 0x0F650000ame cisco
txBufQ: 0x0F651000ord> with the username and p
txPakInfo Arrayo use Index vcd pak Ptr particle Ptr .
For more informati
----- --- ------- ------------the QUICK START
rx_particleArray: Index ParticlePointerur router or go to http:/
  1. 0x475C3080
VC QoS Summary privi
-------------- Active Configured Scheduled line vty 5 15 acces Connectionsn VCD VPI/VCI COS PCR SCR/MCR COS PCR SCR/MCR transport input telnet ! schedul
-------- ! end
yourname#
Tx Queues: ||| VCD(VPI/VCI) Queue tcqTailbase Tail Head control bufAddr aal5Ctrl cellHdr
OAM pak statistics [vcd/tx/dropped]:
1/0/0 OAM enqueue failures : 0 OAM Bad VCD drops : 0 OAM cells handled inline: 0 OAM Max Tx time Statistics: 1 : < 4 msec OAM used samples : 0 OAM ignored samples : 0
Queue Statistics
-------------------------------------------------------------------------------------------------------------------------------------------- Output of sh run command yourname#sh run Building configuration...
Current configuration : 2908 bytes ! version 12.4 service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption ! hostname yourname ! boot-start-marker boot-end-marker ! logging buffered 51200 warnings ! no aaa new-model ! ! ip cef ! ! ip domain name yourdomain.com ! multilink bundle-name authenticated ! vpdn enable ! vpdn-group pppoe request-dialin protocol pppoe l2tp tunnel receive-window 1024 ! ! voice-card 0 no dspfarm ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! username admin privilege 15 secret 5 $1$Aghh $UrF3mUbbDjfR3ngV0Ax4P0 archive log config hidekeys ! ! ! ! ! bba-group pppoe global ! ! interface GigabitEthernet0/0 description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE
0/0$ ip address 192.168.1.1
255.255.255.0 ip nat inside ip virtual-reassembly duplex auto speed auto ! interface GigabitEthernet0/1 ip address 172.24.161.189
255.255.255.252 duplex auto speed auto ! interface ATM0/0/0 no ip address no atm ilmi-keepalive bundle-enable dsl operating-mode adsl2+ hold-queue 224 in pvc 0 0/35 pppoe-client dial-pool-number 1 ! ! interface Dialer1 mtu 1492 ip address negotiated ip nat outside ip virtual-reassembly encapsulation ppp dialer pool 1 dialer-group 1 ppp authentication chap callin ppp chap hostname doeacc_gkp ppp chap password 0 manmohan ! router rip version 2 network 172.24.0.0 network 210.212.51.0 ! ip route 0.0.0.0 0.0.0.0
172.24.161.190 ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/1 ip route 0.0.0.0 0.0.0.0 Dialer1 ! ! no ip http server ip http access-class 23 ip http authentication local no ip http secure-server ip http timeout-policy idle 60 life 86400 requests
10000 ip nat inside source list 1 interface Dialer1 overload ! access-list 1 permit 192.168.1.0
0.0.0.255 ! ! ! ! ! ! control-plane ! ! ! ! ! ! ! ! ! ! gatekeeper shutdown ! banner login ^C
----------------------------------------------------------------------- Cisco Router and Security Device Manager (SDM) is installed on this device. This feature requires the one-time use of the username "cisco" with the password "cisco". The default username and password have a privi vel of 15.
Please change these publicly known initial credentials using SDM or the IOS CLI.
Here are the Cisco IOS commands.
username privilege 15 secret 0
no username cisco
Replace and with the username and password you want to use .
For more information about SDM please follow the instructions in the QUICK START
GUIDE for your router or go to
^C ! line con 0 login local line aux 0 line vty 0 4 access-class 23 in privilege level 15 login local transport input telnet line vty 5 15 access-class 23 in privilege level 15 login local transport input telnet ! scheduler allocate 20000 1000
! webvpn cef ! end
Please help so that the card starts working.
Thanks n Regards Mickey
Thanks for the complete report.
I have not used pppoe very much but the config for pppoe over dsl that I have used is:-
interface ATM0 no ip address dsl operating-mode auto
pvc 0/xx ! varies with ISP encapsulation aal5snap pppoe-client dial-pool-number 1
no vpdn group configured
I have a different one that was: pvc x/xx pppoe-client dial-pool-number 1
Hmm. I would try dsl opeerating-mode auto to start with and check the vpi/vci for the PVC.
