Cisco 3620, interfaces question
Apr 25, 2006 8 Replies
Jump to replies (8)
Cisco 3620, interfaces question open original image
I have a 3620 router that hase 2 ethernet Interface but for some reason I only can see one of them, physically its there and if I connect a cable the led will be on, on both interface. Can someone tell me how to access it. Thanks-Rob
Building configuration...
Current configuration: ! version 12.0 service timestamps debug uptime service timestamps log uptime no service password-encryption ! hostname Router !
! ip subnet-zero no ip routing ! ! ! interface FastEthernet1/0 ip address 10.10.10.1 255.255.0.0 no ip directed-broadcast no ip route-cache no ip mroute-cache full-duplex ! ip classless ! ! line con 0 transport input none line aux 0 line vty 0 4
login ! end
Cisco Internetwork Operating System Software IOS (tm) 3600 Software (C3620-I-M), Version 12.0(28c), RELEASE SOFTWARE (fc1) Copyright (c) 1986-2005 by cisco Systems, Inc. Compiled Wed 30-Mar-05 15:32 by pwade Image text-base: 0x60008918, data-base: 0x6066E000
ROM: System Bootstrap, Version 11.1(7)AX [kuong (7)AX], EARLY DEPLOYMENT RELEASE SOFTWARE (fc2)
TerraceRouter uptime is 1 minute System restarted by power-on System image file is "flash:c3620-i-mz.120-28c.bin"
cisco 3620 (R4700) processor (revision 0x81) with 12288K/4096K bytes of memory. Processor board ID 05970422 R4700 processor, Implementation 33, Revision 1.0 Bridging software. X.25 software, Version 3.0.0.
1 FastEthernet/IEEE 802.3 interface(s) DRAM configuration is 32 bits wide with parity disabled.
29K bytes of non-volatile configuration memory.
4096K bytes of processor board System flash (Read/Write)
Your running config and the "show version" output both indicate that there is only one fast-ethernet interface. So, as far the IOS running on that system is concerned, there is only one FE interface and so there is no way you are going to be able to access the "second" one.
Are you sure that there is a second FE port? Note that sometimes a single ethernet port on a router will have two physical ports -- one for a GBIC or SFP connection and another for a RJ45 cable connection. However, only one physical port can be used at one type and that is controlled by the "media-type" interface sub-command in the configuration. I am not familiar with the 3620 enough to know if maybe two such physical interfaces for a single FE port is misleading you into thinking that you have two FE ports.
Cisco da Gama
Look for the network module names on the slot faceplates - for example NM-1FE-TX
Post your findings
The slots in s 3620 are numbered 0 for the right-hand slot and 1 for the left-hand slot.
So with an interface of FastEthenet 1/0, you clearly have a network module in slot 1 - the left-hand slot.
Is there also a network module in slot 0 and if so of what type?
Get the NM (network Module) name and verify that your current IOS supports that NM. Also verify that your hardware supports the NM
HTH Martin
Fast ethernet 1FX-TX on both 10/100 baseTX
Router#sh diag Slot 0: Fast-ethernet port adapter, 1 port Port adapter is disabled Port adapter insertion time unknown EEPROM contents at hardware discovery: Hardware revision 1.0 Board revision A0 Serial number 11265612 Part number 800-03490-02 Test history 0x0 RMA number 00-00-00 EEPROM format version 1 EEPROM contents (hex): 0x20: 01 44 01 00 00 AB E6 4C 50 0D A2 02 00 00 00 00 0x30: 50 00 00 00 98 11 02 00 FF FF FF FF FF FF FF FF
Slot 1: Fast-ethernet port adapter, 1 port Port adapter is analyzed Port adapter insertion time unknown EEPROM contents at hardware discovery: Hardware revision 1.0 Board revision A0 Serial number 10690719 Part number 800-03490-02 Test history 0x0 RMA number 00-00-00 EEPROM format version 1 EEPROM contents (hex): 0x20: 01 44 01 00 00 A3 20 9F 50 0D A2 02 00 00 00 00 0x30: 50 00 00 00 98 11 13 00 FF FF FF FF FF FF FF FF
Looks like you may have 2 NM-1FE-TX modules. The one in slot0: shows disabled. Try swapping them around. Also remove the NM in slot 1: and see if the NM in slot 0: is recognized.
URB
