4006 CatOS Question
Jan 22, 2009 4 Replies
Jump to replies (4)
Is there a way to clear the counters on just one interface/port in CatOS? I know how to do it in IOS, but I haven't found a way in Cat. Suggestions or is it that this is not port of the OS?
TIA Lovejoy
=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D
clear counters
Thanks for the reply, but there is no option available...
(enable) clear counters ?
TIA Lovejoy
=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D
What ver of code you running? I'm assuming it's dated, as all the versions I've used for the past 7-8 years has had this command available. If you don't have clear counters mod/port or clear port counters, you probably can't do it for individual ports. There shouldn't be any harm is resetting them for all ports, you can always put into an excel if you needed them for historical value.
This thing is WELL past EOL. We are supposidly going to replace it this year....
WS-C4006 Software, Version NmpSW: 7.6(1) Copyright (c) 1995-2003 by Cisco Systems, Inc. NMP S/W compiled on Apr 16 2003, 18:56:05 GSP S/W compiled on Apr 16 2003, 16:56:33
System Bootstrap Version: 5.4(1)
Lovejoy
