wireless adapter vs wireless G Desktop Network Card
Jul 11, 2005 2 Replies
I am new to wireless and will be hooking up next week. I bought a Belkin High-Speed Mode Wireless G Desktop Network Card for $50. Saw this GIGABYTE GN-WPEAG PCI Wireless Network Adapter on net for about same price. Is there a difference between them I should be looking for?
Thanks,
Tony
Probably not but if you get one with the "remote" antenna, it might help you if the box is housed in a compartment under your desk. For example?
Nope desk is wide open so guess will stay with Belkin since it's here now. Thanks a lot for helping. Best regards, Tony
