Extending my house wireless
Nov 07, 2004 5 Replies
Jump to replies (5)
Take the laptop out to the garage and place it in the location where you want to place the desktop. If you have a good signal, all is well. If not, your best bet is to check out a high gain directional antenna for the WMP54G.
Wayne wrote:
I still don't understand it. I currently use a Linksys WRT45G for my two hardwired desktop computers and the wireless feature for my wireless laptop. My wife wants to put a new desktop computer in our detached garage some 190 feet away, and wishes to have wireless internet access via my WRT45G. Would it be as easy as installing the Linksys WMP54G (Wireless-G PCI Adapter) in her new computer, or is the distance too far?
If the distance is too great for a high speed connection, is the alternative to buy a Linksys WAP54G (Wireless-G Access Point), put it in bridge mode, and hardwire her computer to it via the Ethernet plug on her computer?
Am I missing something here?
Wayne
I have a desk top in both my wood shop and in one of my garages running off a WRT54G over a distance of just a little over 200 foot....
I do use high Gain Antennas (Radio Shack Linkysy brand) on the access point... and I get a "fair"signal in both building :most of the time"...NOT ALWAYS...and the speed sometimes leaves a lot to be desired......
I just purchased a WRE54G range expander a few days ago that I am playing with .. .but have not gotten to the point that I can say that it works or not...... I do know the Range Expander demanded that I upgrade the firmwear in my WRT54G ....long story in itself.... in that I lost all my wireless connections after the firmware upgrade and it took almost all day getting everything back to square one and working ..
Just may have thrown some money away.... who knows... and honestly I do not care... I really do NOT NEED a wireless connection in those buildings...but what do you do with 2 old computers besifdes tossing them in the trash can...
Bob Griffiths
You could also go to the Sveasoft firmware for the WRT54G and see if upping the signal strength helps?
Bill
What we actually have are two radio transceivers. Boosting the power output of the AP transmitter will not increase the AP receive sensitivity, so the received signal from the garage may still be marginal.
On the other hand, a high gain antenna will maintain the transmitters power output over longer distances and increase signal strength of the received AP signal.
Happy Canuck wrote:
I had a similiar problem that you described. My Linksys WRT54GS was
next to the cable modem in the basement. As as result, half of my
house had essentially no signal. I played around with signal boosters
at the basement AP, however, they do nothing to improve the signal from
the laptop back to the AP. A wireless card with a directional antenna
may work for you since the computer will be a desktop, however, for my
laptop it didn't seem practical.
My solution was to buy another WRT54GS and use it as a repeater. I
installed the latest Sveasoft Alchemy firmware on both units which was
easy. In the Sveasoft forum there are "how to'" guides to set up the
second router as a repeater. The whole thing took my about 1 hour to
set up. The end result...I can plug the second router (repeater) into
any outlet on my first floor and it rebroadasts the signal to the rest
of the house. No part of my house is weak. Encryption/security is
unaffected. The transmission rate is half'ed, however, I notice no
practical diference. I love it.
Rick
