adhoc network trouble
Jul 11, 2005 1 Replies
Hi!
I've got a little problem, maybe some of you could help.
I want to connect 2 computers via wlan using ad hoc mode. Everything seems to go ok till I try pinging one or another.100% of packets is always lost. there's the same ssid, cards seem to comunicate - quality of link is great and so on.
Maybe I do something wrong I don't know. Please help if u can.
And now technical info:
Pc: d-link DWL-510 windows xp prof. SP2 firewall is DISABLED ssid: 1234 no WEP, open authentication ip: 192.168.0.1 mask 255.255.255.0 DNS: 194.204.159.1 workgroup : home
Notebok: d-link DWL-610 pcmcia windows xp home SP2 firewall is DISABLED ssid: 1234 no WEP, open authentication ip : 192.168.0.10 mask 255.255.255.0 DNS: 194.204.159.1 worgroup: home
Both cards are working when attached to infrastructure network with linksys wless router.
Ad-Hoc and the Windows O/S is a hit or miss situation. In addition, it can be working and then it goes to left field at the drop of a hat from the posts I have read concerning this.
Duane :)
