Which Wireless Network Adapter, PCI card or USB
Jul 22, 2006 6 Replies
patricklamarbrown
I don't think the type of adapter is going to make a difference in getting a stronger signal from a weak one. Your best bet is to find a closer spot.
I am interested in getting a wireless adapter for my desktop to periodically hop onto ambient unsecured wireless signals to check my email. I'm wondering which make and type will work best, a PCI wireless network adapter or a USB wireless network adapter. Maybe there is no difference, but if there is I'd like to know about it. My roommate has a notebook computer and with it she finds we are in range of about six wireless networks, but all show a low or very low signal strength. So I'd be interested in an adapter that will be best at picking up these low-strength signals. Most of the networks within range appear to be Linksys. I guess that means I should probably go witrh a Linksys product to maximize the possibility of picking up the signals.
Thanks
On 22 Jul 2006 09:58:23 -0700, "dejola" wrote in :
Do you also shoplift, or only steal service?
Getting Permission First.
I have tried both! I think that PCI wireless adapters can perform better than USB because PCI ones always equiped with higher gain antennas.
Naim
dejola wrote:
On 23 Jul 2006 07:23:53 -0700, "Panda" wrote in :
Depends. Small USB dongle devices do have limited antennas. But not all USB devices are dongles, and some USB devices have better antennas than most PCI cards. Case in point: Hawking HWU8DD
Bad analogy, as I'm sure you know.
On 23 Jul 2006 08:38:39 -0700, "dejola" wrote in :
