What is a wireless adhoc?
Dec 22, 2005 10 Replies
Jerry Park
That is where two systems connect directly with their wireless cards rather that through an access point.
Waste of time with your response. Why did you even bother?
Who died and made you the Newsgroup cop. How much time does it take for you to hit the delete button on your keyboard? You are also sticking your foot in your mouth. It takes just as much time for me to write in the newsgroup as it would to enter the search phrase in Google. And who are you to determine what is or is not a basic question?
By responding to me at all, you are being hypocritical. Now quit wasting my time fruitloop.
Dunno, try Google "what is a wireless adhoc"
Because every now and then the frustration level of answering questions for people who can't be bothered to do the slightest bit of research gets to be too much. For the record, I'll bet David actually _did_ do that google, just to make sure it told you what he expected it would.
In future, you'd do well to try not antagonizing the regulars on a newsgroup you're hoping will answer questions for you.
LOL. He's just the newsgroup expert. Don't bother with any more snarky responses to me, because you're in the killfile.
Did you actually try it? It returns a whole load of responses giving you your answer.
Probably on the dubious assumption that you might learn to use Google or some other search engine BEFORE you ask such a basic question. I don't mind answering questions or offering explanations on technical issues that are difficult to understand. However, I do mind compensating for what appears to be laziness on your part. Search first, read, and then ask.
That may be so, hence it begs the question why you're unable to Google (since it takes you the same amount of time) and yet expect others to give their time to freely answer a basic question that is already incredibly well documented. :)
Merry Christmas!
