If I use xp firewall, do I need to use my router's firewall?
Dec 17, 2005 2 Replies
preston.gralla
Yes, you should still use your router's firewall. The router's firewall is designed to protect your entire network, while the XP firewall only protects an individual PC.
I have the xp firewall enabled, so do I need to use the router's built in firewall for my wireless network?
Go Tyler wrote:
You need to enable the router's protection abilities including its FW. You can use a personal FW behind the router if you like but you need to enable the router's FW to protect the network.Again, get on the phone with the router's tech support and let them help you.
Duane :)
