VOIP Gateway Port Speed
Feb 15, 2006 3 Replies
Jump to replies (3)
Hello
I have a SunRocket AC-211-SR VOIP Gateway. It's label show's that it works at either 10 or 100mb. Anyone know a way to force the unit to run at 10mb? I'd like to use VOIP GW to a router port that only works correctly at 10mb.
Thanks for any help or advice
Terry
Surely the link should auto-negotiate to the fastest speed *both* ends support..? I have a printer server that only works at 10Mbit, when I plug it into my 100Mbit switch the LED that indicates 100Mbit doesn't come on, indicating that port is running at 10Mbit.
Just plug it in and see what it does.
Ivor
Ivor
It if worked I wouldn't be trying to figure out how to do the workaround. The problem is auto-negotiate. I need it off so I can force it to a speed where the port works rather then the 100MB that it's thinks it's working at
Ivor
