voip for my company
Nov 14, 2006 4 Replies
Jump to replies (4)
voip for my company open original image
I work for a company with 14 analog phone lines and about 40 phones. Our phone vendor is trying to sell us on an IP Phone system since our systems is outdated. We have a fairly small network, a few switches, a router to our ISP, file server etc.. Would an IP phone system use the switches we have or do they require new ones? Also would we be getting rid of our 14 phone lines from our local phone company? If so, where would calls outside our building go to? I understand how it would work inside our building, with everything running over our data network, but what happens for outgoing calls? Do these IP systems just use the analog phone lines, or does the phone company give us some sort of IP line(s)?
Hi Bill,
You may wish to investigate Cisco's Voice Solutions (IP Communications) Designer:
as well as the Bandwidth.com VoIP Test Tool:
Sincerely,
Brad Reese
Bill,
Here is another link that talks about the Cisco IP Telephony products.
My suggestion would be for you to use the Partner Locator tool on Cisco's website to find the closest authorized IP telephony partner.
Regards,
Phil Schneck
Hmm, sounds like questions best to ask of the vendor that is proposing this to you?
The thing with VOIP is, you don't really want bursts on your data network to interfer with your voice network, so most companies run VOIP traffic in a seperate VLAN or a seperate network altogether.
Typically, you'd probably be looking at keeping the POTS lines and run them through an IP gateway, although LECs are starting to deliver lines over VOIP connections as well.
But, overall, the one really to ask is your vendor what they are proposing. You could go either way on alot of this.
Bill,
You may also wish to investigate the VoIP Executive Guide:
Sincerely,
Brad Reese Cisco Technical Forums
