Compact PBX with one FXO port?
Apr 13, 2007 2 Replies
Carl Navarro
I know where to look, I just don't know what I'm looking at. Try these two URL's solution is about $600. Another source with a pay-as-you-go plan is: and let me know if you spring for the Welltech box, I'm looking very seriously at it. Carl Navarro
Compact PBX with one FXO port? open original image
Hello
I'm looking for a solution for a friend who needs a very basic PBX that would look like the Linksys SPA-9000 with the following features:
- solid-state PBX with standard features like ring group, call transfer, etc.
- support for up to 5 VoIP accounts
- one FXO port to handle an incoming POTS line
They don't know anything about telecom and VoIP. That's why I'd like something that just works, and am reluctant to tell them to get a PC with Linux + one FXO card + Asterisk.
If only Linksys offered an FXO port with either the SPA-9000 or their WRT54G router, it'd be the ticket.
Thanks.
Try these two URL's
That solution is about $600.
HTH and let me know if you spring for the Welltech box, I'm looking very seriously at it.
Carl Navarro
Thanks for the pointers.
