usb serial issue honeywell panels
Dec 22, 2007 8 Replies
Jump to replies (8)
seems to me someone posted this before about using a usb to serial port adapter and honeywell panels something specail you had to do to make it work properly
Yes. You should use the Keyspan 19HS model.
Jim Rojas
Nick Markowitz Jr. wrote:
where would I aquire one of those I have a belkin which seems available most places around here
I bought a couple from ebay. They run $30 new.
Jim Rojas
Try Office Max or Staples.
Jim Rojas
They sell them at ADI. It is a regular stock item, not special order.
If it works then great but Honeywell still doesn't recommend it
