CM11A with SERIAL to USB problems
Oct 30, 2006 4 Replies
Jump to replies (4)
Hello,
I am not being able to hook the CM11A interface via a SERIAL to USB converter. I am using my laptop which doesn't have a serial port. I am on windows XP sp2 and ActiveHome seems not to be able to communicate with the device. Any ideas? Thanks in advance.
Does the USB virtual serial port show up in Device Manager? In the Start menu, right-click My Computer. Click Properties. Click Hardware. Click Device Manager.
Does it show up in ActiveHome? IIRC, ActiveHome is rather inflexible about port numbering.
The CM11A only uses TXD & RXD (plus RI but that's not a factor) so there should be no problems due to unsupported handshaking lines.
I haven't tried it under XP but I never had problems us>Hello,
snipped-for-privacy@yahoogroups.com
Hi Dave,
Actually the USB virtual serial port is showing in the device manager and is working well with other serial devices.
How? where? All I can do in ActiveHome is test communications which always fails (choosing the right com port (com2)
Regards.
Dave Houst> Does the USB virtual serial port show up in Device Manager? In the Start
Personally, I've had problems with ActiveHome under XP with USB-to-serial *as well as* real serial ports. The almost-identical IBM Home Dirtector software works wothout a problem, though, with both.
Anyway, here's another thread that deals with the same issue:
Hope this helps...
Regards,
Anand
