ZoneAlarm install problem? set tvdump????
May 04, 2005 1 Replies
dak
The "SET tvdumpflags=10" line is written to the "" file in the root directory of your "C" drive ("C:\"). The line itself is merely setting a variable for ZoneAlarm. You can edit "" with a plain text file editor like Notepad.
Each time I install a new version of zonealarm I get another entry of 'set tvdumpsomething' that gets executed (4 times now after 4 upgrades) at boot up in win98.
What file is executing this at boot up so I can delete 3 of the 4 entries?
The "SET tvdumpflags=10" line is written to the "autoexec.bat" file in the root directory of your "C" drive ("C:\\autoexec.bat"). The line itself is merely setting a variable for ZoneAlarm. You can edit "autoexec.bat" with a plain text file editor like Notepad.
