please help with a funky IOS install
Apr 24, 2007 0 Replies
I've got a 1720 that I want to use a "Single-Port Ethernet WIC" (Cisco WIC-1ENET) with. So I put the WIC into Slot 0, but my IOS didn't know what it is. My IOS was too old so I needed a new IOS (which I have), called "c1700-y-mz.122-4.T1.bin".
I'm talking to this 1720 with HyperTerminal. I erased everything I could discover as eraseable (nvram, flash), power cycled the router, and ended up at the rommon. Eventually I figured out xmodem to get the .bin file onto the flash with "xmodem -cyx 122-4.T1.bin" and have HyperTerm send over the IOS file.
All this seemingly goes well, the xmodem completes without errors. So then I have it "reset" and here's what it does (my questions are below)
System Bootstrap, Version 12.0(3)T, RELEASE SOFTWARE (fc1) Copyright (c) 1999 by cisco Systems, Inc. C1700 platform with 16384 Kbytes of main memory
program load complete, entry point: 0x80008000, size: 0x3a6a38 Self decompressing the image : ################################################# ################################################################################ ################################################################################ ################################################################################ ################################################################################ ################################################################################ ########### [OK]
Hello from IFS_TYPE_ROM successful type-check
%SYS-6-BOOT_MESSAGES: Messages above this line are from the boot loader. boot of "rom" using boot helper "flash:122-4.T1.bin" failed error returned: rom loadprog: error - on file open boot: cannot load "rom"
Restricted Rights Legend
Use, duplication, or disclosure by the Government is subject to restrictions as set forth in subparagraph (c) of the Commercial Computer Software - Restricted Rights clause at FAR sec. 52.227-19 and subparagraph (c) (1) (ii) of the Rights in Technical Data and Computer Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc. 170 West Tasman Drive San Jose, California 95134-1706
Cisco Internetwork Operating System Software IOS (tm) C1700 Software (C1700-Y-M), Version 12.2(4)T1, RELEASE SOFTWARE (fc1) TAC Support:
(c) 1986-2001 by cisco Systems, Inc. Compiled Thu 25-Oct-01 18:52 by ccai Image text-base: 0x800080E0, data-base: 0x80738BD8
cisco 1720 (MPC860) processor (revision 0x301) with 13927K/2457K bytes of memory . Processor board ID JAD03244222 (2971443916), with hardware revision 0000 M860 processor: part number 0, mask 32 Bridging software. X.25 software, Version 3.0.0.
1 Ethernet/IEEE 802.3 interface(s)
1 FastEthernet/IEEE 802.3 interface(s)
32K bytes of non-volatile configuration memory.
4096K bytes of processor board System flash (Read/Write)
Press RETURN to get started!
00:00:04: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to up
00:00:04: %SYS-5-CONFIG_I: Configured from memory by console
00:00:04: %SYS-5-RESTART: System restarted -- Cisco Internetwork Operating System Software IOS (tm) C1700 Software (C1700-Y-M), Version 12.2(4)T1, RELEASE SOFTWARE (fc1) TAC Support:
00:00:04: %SNMP-5-COLDSTART: SNMP agent on host RAP_DSL is undergoing a cold start
00:00:05: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to down
00:00:05: %LINK-5-CHANGED: Interface Ethernet0, changed state to administratively down
00:00:06: %LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet0, changed state to down
So exactly what is up with the first boot attempt that gives me this message...
I'm a newb but I guess this is some sort of boot order of operations, where this (above, the first attempt) is failing (for some reason), but the second alternate attempt is "working". But I don't know why the first one fails (or how it's different). And I don't know a way to tell the router to "remember" the "one that works" and boot from it straight away next time.
But at least it actually sees the WIC (Ethernet0), so I hope I'm making progress. I don't understand why the flash .bin fails, but then works, and why it decompresses it twice on every reset/boot sequence.
