software features
Apr 14, 2005 3 Replies
Jump to replies (3)
software features open original image
This is my first time login to Cisco.com for downloading image. What I am looking for is an image that supports cef load balancing.
How do I know which Feature Set will support CEF load balancing ?
And could you please show me some URL that explains what Feature Set names mean.
Thanks for your advice,
DT
In article , snipped-for-privacy@yahoo.com wrote: :This is my first time login to Cisco.com for downloading image. :What I am looking for is an image that supports cef load balancing.
:How do I know which Feature Set will support CEF load balancing ?
Any release in the last several years should support CEF load balancing, if it supports CEF at all.
CEF's load balancing ability goes back as far as IOS 11.1(17)CC [for the 7200 and 7500]
In 12.0,
"Per-packet load balancing via CEF is not supported on Engine 2 Gigabit Switch Router (GSR) line cards (LCs)."
but that was the only restriction noted even then.
You may wish to investigate the Cisco IOS Software Selector ( browse CEF features in alphabetical order ):
Sincerely,
Brad Reese BradReese.Com Cisco Resource Center Toll Free: 877-549-2680 International: 828-277-7272 Website:
Thanks, Walter. I just downloaded the 12.3 for my 2621 and I can practise those commands.
DT
