Checkpoint FW1 failover requirements?
Feb 23, 2005 1 Replies
Most relevant reply
Thomas Marko
Yes, there is a functionality in FW-1/VPN-1 which is called CPHA which can do standby HA but can also do Load Balancing (depends on how many coins you'll through into the slot ;-) You can also realize HA using the protocol VRRP (builtin in Nokia and Nortel Alteon Appliances…
Hello, We currently are running a Checkpoint NG firewall on a Solaris box with an Enterprise license for unlimited users.
I am looking to set up another identical Solaris box running Checkpoint to be a failover/standby when the first one would fail. I am not looking for load balancing.
My question: Is this functionality built in to the NG firewall software itself? And would we have to pay for another ($20K) Enterprise licence to make this happen?
If this scenario requires another Enterprise license to be purchased, it would probably just make more sense to buy two Cisco PIXes in a standby/failover configuration and save a bunch of money.
Any help or advice would be greatly appreciated. Thank you!
You can also realize HA using the protocol VRRP (builtin in Nokia and Nortel Alteon Appliances, and ?).
AFAIK you will need a license for the second module, but not for a second management server. If you use CPHA you will have to purchase a ClusterXL license.
Please do not compare a Check Point FW-1/VPN-1 with a Cisco PIX. Just looking for the price when buying a firewall is IMHO the wrong way.
Cheers, Thomas
