Downloadable IP ACLs feature
Sep 08, 2005 6 Replies
Jump to replies (6)
Downloadable IP ACLs feature open original image
hi all
in his Secure ACS server (for windows) Cisco has this : Downloadable IP ACLs-Cisco Secure ACS version 3.3 extends per-user ACL support to any Layer 3 network device that supports this feature.
what are "network device that supports this feature" ? what do they mean ? I am not able to make it work on a 1721 router.
any tips ?
regards.
In article , dominix wrote: :in his Secure ACS server (for windows) Cisco has this : :Downloadable IP ACLs-Cisco Secure ACS version 3.3 extends per-user ACL :support to any Layer 3 network device that supports this feature.
:what are "network device that supports this feature" ? :what do they mean ?
The PIX for one; the new ASA series for another. Possibly the VPN3000 series.
The supported devices are,
PIX Firewalls VPN 3000-series Concentrators
It will not work on routers.
[Please quote some context, as not everyone's newsreaders supports threading, and messages can arrive out-of-order]
:The supported devices are,
:PIX Firewalls :VPN 3000-series Concentrators
:It will not work on routers.
As I indicated before, it is also supported on the Cisco ASA series of security appliances.
thank for your precise reply, ... so how do you guys manage access-list on routers ?
cheers
In article , dominix wrote: :so how do you guys manage access-list on routers ?
Master copy on tftp server, tftp in the update at need. But then I don't have any per-user ACL needs on our routers.
Hi !
You could use the RADIUS-attribute cisco-av-pair for downloading per-user ACLs to the router.
Thomas
"dominix" schrieb im Newsbeitrag news: snipped-for-privacy@o13g2000cwo.googlegroups.com...
