Upgrading to 2950 switch from 2924 - process?
Apr 14, 2005 2 Replies
BradReeseCom
You may wish to investigate the Cisco Catalyst 2950 Configurator Wizard: Brad Reese Cisco Resource Center Toll Free: 877-549-2680 International: 828-277-7272 Website:
Upgrading to 2950 switch from 2924 - process? open original image
Hi: Presently have a single 2924 Switch connected to a 1720 Router and a PIX
515. 4- ports on the 2924 have died so we are replacing with a 2950.
Would like this to be as quick and non-disruptive as possible. Ideally pre-configure the new 2950, then simply disconnect the 2924 and make the connections to the 2950.
  1. Is this practical?
  2. What information do I need to get from the 2924 in order to configure the 2950?
  3. Am I safe in assuming the 1720 and 515 won't require any changes?
Thanks PS
Sincerely,
Brad Reese BradReese.Com Cisco Resource Center Toll Free: 877-549-2680 International: 828-277-7272 Website:
You should be able to use the same config on the 2950. This should get you at least 98% there. When you paste in the new config, note any lines that the 2950 doesn't like.
Scott
