SDM Application does not open in another window
Jan 14, 2008 2 Replies
I have an 857 and it is working well. I want to add a tunnel so I can get my work emails from home using the VPN (I think i am right in believing this will be possible) anyway I have a new laptop and the config is not allowing SDM to open. All I get after punching in the IP into the SDM Launcher is a new tab in Firefox and nothing else. No clues, messages, logs or anything I can find. My firewall (Kaspersky) is set to have no blocking of pop-ups and so too is IE (incase the OS is involved somehow) and Firefox. Even temp bringing down of firewall makes no difference. What am I missing please? What must I do to get SDM (locally installed) to run?
If u can use IE not Firefox i faced same issue with firefox and then i switched to IE for SDM. You must have JAVA? Are you using VSITA on laptop?
Rgds...CK
Thanks. This has got me a little further. I'm using XP Pro and now with IE as my default the SDM Launcher launches IE but even though I have requested the IP a little dialog box appears asking for the IP again. Once entered I then get a familiar page saying don't close this, followed by a request for my SSH details. I have to confess I do not link to my router using a secure link (no https). I should, I belive be asked for my "simple" username and password. What now?
James
