L3 switch issue
Jul 04, 2006 7 Replies
Jump to replies (7)
L3 switch issue open original image
Folks, My setup as follows.......The L3 switch is used to route between the vlans.The subinterface fasthethernet 1.1 is connect to a L2 switch, which host the servers and clients.Now I want to connect one of my less frequently accessed server,directly to the L3 switch ,to the same VLAN as the Fastethernet 1.1 is connected.How do i go about.I have given the config file below... I want to put the server on interface Fe15 of L3 switch.
The switches i am using are all cisco.The L3 switch is 2948
Building configuration...
Current configuration: ! version 12.0 no service pad service timestamps debug uptime service timestamps log uptime service password-encryption ! hostname aspcrt1 ! enable secret 5 $1$/JqD$Jih8rUUam.U0hr3FOWQZ/1 enable password 7 02050D480809 ! ip subnet-zero no ip domain-lookup bridge irb ! ! ! interface Port-channel1 no ip address no ip directed-broadcast hold-queue 300 in ! interface Port-channel2 no ip address no ip directed-broadcast hold-queue 300 in ! interface FastEthernet1 no ip address ip directed-broadcast ! interface FastEthernet1.1 encapsulation dot1Q 1 native ip address 10.0.11.254 255.255.255.0 no ip redirects ip directed-broadcast interface FastEthernet15 no ip address no ip redirects no ip directed-broadcast
.... banner motd ^CUnauthorized access is prohibitted! ^C ! line con 0 transport input none line aux 0 line vty 0 4 password 7 1304040208 login transport input telnet ! end
You could just configure ...
int vlan 1 ip address 10.0.11.254 255.255.255.0
int Fa1 description attached to l2 switch switchport trunk allowed vlan 1 switchport mode trunk switchport trunk encaps dot
int Fa2 description attached to server switchport trunk allowed vlan 1 switchport mode trunk switchport trunk encaps dot
But if the server's hardly ever accessed why use up a perfectly good L3 switch port?
BernieM
BTW ... the use of 'password' is insecure. There are plenty of decrypt engines online ... "1304040208" decrypts to "aspc". I realise your config didn't have any public addr's but believe it or not I've seen posts that did ... with 'passwords' as well. Where possible replace them with "secret" which uses an MD5 hash, but of course it's better practice to snip any sensitive unnecessary info out before you post device configs.
Just a bit of advice ... not a lecture.
BernieM
If you do a "show tech", the 'config' part has all(/most?) password data removed.
Trouble is of course that sh tech can be quite a lot of data. (500k?). Depending on how you are accessing the router the size may or may not be an issue.
I just did a CORE1#sh tech-support ? bridging L2 related information cef CEF related information ipc IPC related information ipmulticast IP multicast related information isis CLNS and ISIS related information ospf OSPF related information page Page through output password Include passwords | Output modifiers
Never seen the options before.
If yoo ARE NOT running isis then show tech isis
is the equivalent (roughly) of sh tech config which does not exist.
Nice I say.
Bernie, Thanks a lot.Yeah its an internal switch and only I have access to it.As you said, it is better practice to go for secret.
But am just wondering whether anything can be done on my existing config to meet the needs.Because the switch is configured for other vlans too and it mainly acts as a router.
Cheers
Cheers
Just a thought ... you could create a bridge-group between Fa1.1 and the interface you want to connect the server to.
BernieM
2948G-L3 is more of a switching router than a routing switch, so the config required to achieve this is a little ass backwards. Steps are:
- Configure a unique bridge group for these ports
- Move the IP address from Fa1.1 to the BVI interface of the new bridge group
- Configure Fa1.1 and Fa15 as bridge-group members
I would recommend reading
understand what's required here and why.
Andy
