C6500 Earl L3 Asic warning
May 16, 2006 5 Replies
Jump to replies (5)
Hello,
since 2 days i receive some strange messages in the logfile:
May 16 11:57:02: %EARL_L3_ASIC-SP-3-INTR_WARN: EARL L3 ASIC: Non-fatal interrupt Packet Parser block interrupt May 16 11:58:03: %EARL_L3_ASIC-SP-3-INTR_WARN: EARL L3 ASIC: Non-fatal interrupt Packet Parser block interrupt May 16 11:59:04: %EARL_L3_ASIC-SP-3-INTR_WARN: EARL L3 ASIC: Non-fatal interrupt Packet Parser block interrupt
I was unable to find a discription of this error message in the internet. What is causing the message above? Any idea?
Best regards,
Holger Amberg
to see what interrupt counter is incrementing try:
remote command switch show plat hardware earl status | begin Packet Parser
Hello,
Merv schrieb:
Packet Parser block block : Total interrupts - 347205 IP_LEN_INT : 0 IP_SHRT_INT : 0 IP_CS_INT : 347205 QDBUS_CRC_INT : 0 QDBUS_LEN_INT : 0 IB_LEN_INT : 0 IB_SEC_INT : 0
Best regards,
Holger Amberg
So the parser interrupts are due to packets with IP checksum errors.
These errors were also seen in the show mls statistics output display.
I do not believe the message " EARL_L3_ASIC-SP-3-INTR_WARN: EARL L3 ASIC: Non-fatal interrupt Packet Parser block interrupt" is anything that you need to worry about.
You can turn it off with: no mls verify ip checksum
Doan
