Using WIC-4ESW as L3 device
Jun 30, 2006 1 Replies
Hi all,
Is it possible to use a WIC-4ESW as a L3 device in a IOS based router (28xx)
I noticed the MAC addres of the Fa0/0 is the same as the VLAN interfcae Changing the MAC adress of the VLAN interface gives the error: % "mac-address" not valid on this interface
Tom Pouce skrev:
You cant put an IP address directly on the interface but you should be able to run diffirent vlans on diffirent ports and use vlan interfaces to route between them.
-SAto
