Catalyst 1900
Jul 04, 2006 7 Replies
Jump to replies (7)
I just purchased a catalyst 1900 off ebay to get some command line experience with a switch. Well, the switch is menu driven. How can I make it command line driven. If I install a new IOS version "cat1900en.9.00.07.bin" will this make the switch command line driven?
I believe there is an option on the menu to go to command line. If I remember correctly it is K on my switch with enterprise version.
Hi Howard,
You need the "enterprise" version of the S/W for command-line operation. If the menu does not have an option to go to the command-line, then you do not have the "enterprise" version.
Cheers........................pk.
Catalyst 1900 open original image
Hello All
I have an older style 1900 that only goes up to v5.37, well unfortunately I found that out a little too late. I now have a switch without any firmware so am going nowhere fast.
I understand even with a smartnet that the firmware is no longer available (correct if wrong) and as this switch will never go into production, does any knd person possibly have a v5.37 bin they could send me please.
I do understand that this might not be the right way to go about getting the firmware but Cisco don't seem too helpful (EOL product) and it is only to learn with.
Any help or flames appreciated
BR
Ed
Ed skrev:
The old Cat1900 software seems to be available for download still...
Requires login :
-SAto
Thanks for the reply, however my cco login obviously hasn't had enough money thrown at it , so no luck there. I have tried getting a smartnet contract but as I keep getting different answers I guess this is a wild goose chase.
Thanks again
Ed
SAto wrote:
Hi Ed,
Cisco Catalyst 1900 Documentation:
Cisco SMARTnet Pricing has been changed:
You may also wish to investigate Cisco Catalyst 1900 Software Relicensing:
As well as Email - Bobby Thekkekandam, Cisco Systems Customer Support Engineer:
bthekkek at cisco.com
Sincerely,
Hendersonville Road, Suite 17 Asheville, North Carolina USA 28803 USA & Canada: 877-549-2680 International: 828-277-7272 Fax: 775-254-3558 AIM: R2MGrant Website:
