Redundant link between to L3 switches
Nov 24, 2008 4 Replies
Jump to replies (4)
I have two 12 miles distant offices. Cisco 3750 L3 switch on each side are connected via private PTP 1Gbs fiber link. Recently my company installed private PTP wireless backup link in case that fiber gets cut. Please note that wireless link should be up at all the time on standby and kick in when fiber goes down. I should be able to ping or access wireless unit=92s (Motorola OS-Gemini) via its IP address when it is in standby mode. Reason for this is just to test it from time to time. My understanding is that there is two way to achieve this EIGRP (L3) or STP (L2). Can someone can help me decided which way to go and cons and pros of both ways Thank you very much
If you absolutely must have the same L3 networks available in both locations, then you don't really have a lot of choice. However this creates long convergence times (spanning-tree), and requires a lot of maintenance. I would generally avoid this at all costs unless you have specific requirements. Using a nice L3 design with a summarized address space and two links is much cleaner and much faster in terms of failover. While neither solution may work completely uninterrupted, a OSPF or EIGRP solution could easily reconverge while only needing to re-establish application sessions. Bring both links up in eigrp, eigrp will automatically prefer the higher bandwidth path, and if/when it fails, it will route over the backup path. Just ensure you have an adjacency on both links, and you architect l3 properly. Just my 2 cents....
Not sure what you were trying to say "If you absolutely must have the same L3 networks available in both locations" please elaborate Thank you very much
Do you need the same subnet available in both locations (i.e.
10.0.0.0/24 or something similar)? If so, then you will need to architect a solution that puts the same subnet (i.e. vlan) in both locations. This limits your options to trunking or something similar. If you don't need the same l3 network in both location, then create new subnets in the 2nd facility, summarize them together, and advertise them back to the main office. That way each office has two paths to the other's l3 networks, and can failover as necessary in the event of an issue. Unless you absolutely have a requirement for two boxes (one at each location) to be in the same L3 subnet (private vlans for oracle or load balancing servers can drive this type of requirement), I would avoid a l2 based solution.
