L3 interface on 4948
Apr 27, 2010 4 Replies
Jump to replies (4)
I configured "no switchport" with IP address on my 4948 and all is well when I have something plugged into that interface. (I can ping the interface address from nodes attached to the VLANs on the switch and whatever is attached to the L3 interface). BUT, when I unplug nodes directly connected to the L3 port, I can't ping the L3 port IP for some reason. Is there something I need to do so that it remains up even if there are no physical connections to the L3 port?
berkid had written this in response to
: unix wrote:
It is I think possible to have a physical interface up even if nothing is connected.
int x no keepalive
Hmmm. I just tried on an 877. Did not work on the switch ports. They are unusual though.
Not usually something you would ever want to do though. For example RIP could advertise unreachable networks.
Let me clarify. Let's say my L3 port is assigned 10.10.10.11 and I have a PC directly connected to that interface with ip
10.10.10.12. From a VLAN on that switch, I can ping 10.10.10.11 and 10.10.10.12. When I unplug the PC, I can't ping the L3 interface address any more. There has to be a way to keep it up since it's just a virtual ip similar to VLAN ip address that we define when we want to enable VLAN routing. Makes sense?
Yes. berkid and I got it first time round too:)
This is the design behaviour. Why would you want anything else?
Use berkids solution which will looks pretty good to me if it's what you want. I mentioned the no keepalive not because I think it might be intrinsically better but because it might for some reason suit you better. It does work on some interfaces but I forget the details. I don't have access to a
4948 (or a 4500 which amounts to the same thing) to play with.
