Switch Router vlans l2 l3 help
May 04, 2007 1 Replies
Hi i have Switch he is layer2 and have Router Layer3 when i make on switch 2 vlans with difrent subnets
192.168.0.10/24-vlan1(default) and 172.18.0.10/24(vlan100) then they can not see, i know i need to make something on router only what maybe can help me something like logical interface
interface fastethernet 0/0.100 ip address 172.18.0.1 255.255.255.0 description for vlan 100
and i ge this when i try to setup ip address on logical interface % Configuring IP routing on a LAN subinterface is only allowed if that subinterface is already configured as part of an IEEE 802.10, IEEE 802.1Q, or ISL vLAN.
and interface fastethernet 0/0 ip address 192.168.0.1 255.255.255.0 desscription for vlan 1 default
pls help how to make that 2 vlans can see ....
Is the switch a layer 3 switch? Is the router a separate device? If so, you need to trunk the VLANs out to the router and assign the IPs there and ensure routing is turned on. If this is a layer 3 switch, then you need to put the fast ethernets in vlans, create the vlans (interface VLAN1), give them IP addresses, and turn up routing.
