Re Cisco 3620, Interface question-more info
Apr 27, 2006 1 Replies
I have a 3620 router that hase 2 ethernet Interface but for some reason I only can see one of them, physically its there and if I connect a cable the led will be on, on both interface. Can someone tell me how to access it. Thanks-Rob
Building configuration...
Current configuration: ! version 12.0 service timestamps debug uptime service timestamps log uptime no service password-encryption ! hostname Router !
! ip subnet-zero no ip routing ! ! ! interface FastEthernet1/0 ip address 10.10.10.1 255.255.0.0 no ip directed-broadcast no ip route-cache no ip mroute-cache full-duplex ! ip classless ! ! line con 0 transport input none line aux 0 line vty 0 4
login ! end
Cisco Internetwork Operating System Software IOS (tm) 3600 Software (C3620-I-M), Version 12.0(28c), RELEASE SOFTWARE (fc1) Copyright (c) 1986-2005 by cisco Systems, Inc. Compiled Wed 30-Mar-05 15:32 by pwade Image text-base: 0x60008918, data-base: 0x6066E000
ROM: System Bootstrap, Version 11.1(7)AX [kuong (7)AX], EARLY DEPLOYMENT RELEASE SOFTWARE (fc2)
TerraceRouter uptime is 1 minute System restarted by power-on System image file is "flash:c3620-i-mz.120-28c.bin"
cisco 3620 (R4700) processor (revision 0x81) with 12288K/4096K bytes of memory. Processor board ID 05970422 R4700 processor, Implementation 33, Revision 1.0 Bridging software. X.25 software, Version 3.0.0.
1 FastEthernet/IEEE 802.3 interface(s) DRAM configuration is 32 bits wide with parity disabled.
29K bytes of non-volatile configuration memory.
4096K bytes of processor board System flash (Read/Write)
Router#sh diag Slot 0: Fast-ethernet port adapter, 1 port Port adapter is disabled Port adapter insertion time unknown EEPROM contents at hardware discovery: Hardware revision 1.0 Board revision A0 Serial number 11265612 Part number 800-03490-02 Test history 0x0 RMA number 00-00-00 EEPROM format version 1 EEPROM contents (hex): 0x20: 01 44 01 00 00 AB E6 4C 50 0D A2 02 00 00 00 00 0x30: 50 00 00 00 98 11 02 00 FF FF FF FF FF FF FF FF
Slot 1: Fast-ethernet port adapter, 1 port Port adapter is analyzed Port adapter Fast ethernet 1FX-TX on both 10/100 baseTX (it has 2 ethernet jack)
Rob
Part no. 800-03490-02 is a Cisco NM-1FE-TX
Notice that show diag indicates that the NM in slot 0 is disabled so it is probably faulty and need to be replaced
