cisco adsl wic card not working
Apr 07, 2005 0 Replies
As from the object I can't get my 1720 cisco router working If I try to ping the outside I don't get any response (but to the inside there is no problem) my adsl line comes with a static ip, ipoa protocol, LLc encapsulation and G.DMT maybe a faulty hardware? what follows is some commands I run to find clues... Thanks in advance
gwnowin#show dsl int atm0 Alcatel 20150 chipset information ATU-R (DS) ATU-C (US) Modem Status: Showtime (DMTDSL_SHOWTIME) DSL Mode: ITU G.992.1 (G.DMT) ITU STD NUM: 0x01 0x1 Vendor ID: 'ALCB' 'ALCB' Vendor Specific: 0x0000 0x0000 Vendor Country: 0x00 0x0F Capacity Used: 20% 39% Noise Margin: 34.0 dB 29.0 dB Output Power: 20.0 dBm 12.0 dBm Attenuation: 16.0 dB 10.0 dB Defect Status: None None Last Fail Code: None Selftest Result: 0x00 Subfunction: 0x15 Interrupts: 329192 (0 spurious) PHY Access Err: 0 Activations: 1 SW Version: 3.8129 FW Version: 0x1A04
Interleave Fast Interleave Fast Speed (kbps): 1504 0 320 0 Reed-Solomon EC: 0 0 0 0 CRC Errors: 0 0 0 0 Header Errors: 0 0 0 0 Bit Errors: 0 0 BER Valid sec: 0 0 BER Invalid sec: 0 0
DMT Bits Per Bin
00: 0 0 0 0 0 0 0 2 2 2 4 5 5 6 6 7
10: 7 7 6 6 6 6 5 6 5 5 4 3 4 3 0 0
20: 0 0 0 0 0 0 0 0 0 0 0 0 2 2 2 2
30: 3 3 3 4 4 4 4 4 4 4 4 4 4 4 4 2
40: 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4
50: 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4
60: 4 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3
70: 3 3 3 3 3 3 3 3 3 3 2 2 2 2 2 2
80: 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2
90: 2 2 2 2 2 2 2 2 2 2 3 3 3 2 2 2 A0: 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 B0: 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 C0: 2 2 2 2 2 2 2 2 2 2 2 2 2 3 2 3 D0: 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 E0: 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 F0: 2 2 0 0 0 0 0 0 0 0 0 0 0 0 0 0
DSL: Training log buffer capability is not enabled
gwnowin#sh run Building configuration...
Current configuration : 1643 bytes ! version 12.2 service timestamps debug datetime msec service timestamps log datetime msec localtime service password-encryption ! hostname gwnowin ! logging buffered 4096 debugging enable secret 5 xxxxxx/xxxxx/xxxxxxxxx ! username xxxxxx privilege 15 password 7 xxxxxxxxxxxx memory-size iomem 15 ip subnet-zero ! ! ip domain name somewhere.net ip name-server x1.y1.y1.t1 ip name-server x2.y2.y2.t2 ! ip audit notify log ip audit po max-events 100 ! ! ! ! ! interface ATM0 ip address x.y.z.202 255.255.255.252 ip nat outside no ip mroute-cache no atm ilmi-keepalive pvc 8/35 encapsulation aal5snap ! dsl operating-mode auto ! interface Ethernet0 ip address 192.168.2.1 255.255.255.0 ip nat inside no ip mroute-cache half-duplex ! interface FastEthernet0 ip address 192.168.1.1 255.255.255.0 ip nat inside no ip mroute-cache speed auto full-duplex ! interface Dialer0 no ip address ! ip nat inside source list 10 interface ATM0 overload ip nat inside source static tcp 192.168.1.2 80 interface ATM0 80 ip nat inside source static tcp 192.168.1.2 25 interface ATM0 25 ip nat inside source static tcp 192.168.1.2 443 interface ATM0 443 ip classless ip route 0.0.0.0 0.0.0.0 x.y.z.201 no ip http server ! ! access-list 10 permit 192.168.2.0 0.0.0.255 access-list 10 permit 192.168.1.0 0.0.0.255 access-list 60 permit 194.244.1.0 0.0.0.255 access-list 60 permit 192.168.1.0 0.0.0.255 access-list 60 permit 192.168.2.0 0.0.0.255 ! ! line con 0 line aux 0 line vty 0 4 access-class 60 in login local ! no scheduler allocate end
gwnowin#show controllers atm 0 Interface ATM0 is up Hardware is DSLSAR (with Alcatel ADSL Module) IDB: 8161C798 Instance: 8162410C reg_dslsar:68030000 wic_regs:
68030080 PHY Inst:8161E5A0 Ser0Inst: 8160A738 Ser1Inst: 81613B9C us_bwidth:320 Slot: 0 Unit: 0 Subunit: 0 pkt Size: 4528 VCperVP: 256 max_vp: 256 max_vc: 65536 total vc: 1 rct_size:65536 vpivcibit:16 connTblVCI:8 vpi_bits: 8 vpvc_sel:3 enabled: 0 throttled: 0 cell drops: 0 Parallel reads to TCQ:0 tx count reset = 0, periodic safe start = 0 Serial idb(AAL5) output_qcount:0 max:40 Serial idb(RAW) output_qcount:0, max:40
WIC Register Value Notes
--------------- ---------- ---------- FPGA Dev ID (LB) 0x44 'D' FPGA Dev ID (UB) 0x53 'S' FPGA Revision 0x9F WIC Config Reg 0x45 WIC / VIC select = WIC; CTRLE addr bit 8 = 1; OK LED on; LOOPBACK LED off; CD LED on; WIC Config Reg2 0x03 Gen bus error on bad UNKNOWN DSL access Int 0 Enable Reg 0x03 UNKNOWN DSL normal interrupt enabled UNKNOWN DSL error interrupt enabled
DSLSAR Register Value Notes
--------------- ---------- ---------- sdram_refresh: 0x428FFFF intr_event_reg: 0x80 intr_enable_reg: 0x13C FIFOF.FBQE.RQAF.RPQAF.TSQAF. config: 0x660D0A20 UTOPIA.RXEN.RegulateXmit.RMCell.TXEN. Rx Buffer size: 8192. RCT: Large, VPI Bits: 8. status: 0x0 clkPerCell: 11983360 Pre-timer Count: 471 rcid_tableBase: 0x0 rct_base: 0x10000 tstBase1: 0x13C28 TST boot jump. rawCellBase: 0x14300 (0/128) slots used. rpq_base: 0x16000 tsqb(Tx Stat Q): 0x17000 fbq_base: 0x17880 (fbq_count: 128) txChanQueue: 0x18000 rxBuffers: 0x30000 txBuffers: 0x130000 Lookup Error cnt: 0x0 Invalid Cell cnt: 0x0 SCCA Rx Errors: 0x0 SCCB Rx Errors: 0x0 Total Tx Count: 0x1 Total Rx Count: 0x4 Timer: 0x2E6360 DSLSAR Interrupts:0x0 Last Addr:0x12E14
VC QoS Summary
-------------- Active Configured Scheduled Connections VCD VPI/VCI COS PCR SCR/MCR COS PCR SCR/MCR
1 8 /35 UBR 0 n/a UBR 320 n/a
Connections RX RX RX RX RX TX TX TX TX TX TX VCD VPI/ VCI AAL5 AAL2 RAW Chain Drop AAL5 AAL2 RAW TSI Drop MISS
0 0 /0 0 0 0 0 0 0 0 0 0 0
1 8 /35 2 2 0 0 0 0 0 0 0 0
0 1 1 0 0 0 0 0 0 0 0 0 0
TX Queues: |||| VCD VPI/ VCI CtrlStat tcqTail tcqHead control bufAddr aal5Ctrl cellHdr
1 8 /35 A0000 19010 10 11A0 173320 0 0
Summary Serial Device information: AAL5: Tx Interrupts = 1 , Tx BD Service Count = 1 Rx Interrupts = 2 , Rx BD Service Count = 2 RAW : Tx Interrupts = 160 , Tx BD Service Count = 163 Rx Interrupts = 0 , Rx BD Service Count = 0
Detailed Serial Device information:
MPC860 SCC 1 statistics: Serial IDB at 0x8160A738 DCE Unknown (13), clock rate 8000000 idb at 0x8160A738, driver data structure at 0x81612244 SCC Registers: General [GSMR]=0x1980:0x00000030, Protocol-specific [PSMR]=0x8 Events [SCCE]=0x0000, Mask [SCCM]=0x001F, Status [SCCS]=0x02 Transmit on Demand [TODR]=0x0, Data Sync [DSR]=0x7E7E Interrupt Registers: Config [CICR]=0x00365F80, Pending [CIPR]=0x00004802 Mask [CIMR]=0x68200000, In-srv [CISR]=0x00000000 Command register [CR]=0x6C0 Port A [PADIR]=0x1100, [PAPAR]=0x9FCF [PAODR]=0x0000, [PADAT]=0xF9FF Port B [PBDIR]=0x0BC0F, [PBPAR]=0x0F00E [PBODR]=0x00000, [PBDAT]=0x090FC Port C [PCDIR]=0x000, [PCPAR]=0x000 [PCSO]=0x8E0, [PCDAT]=0xF3C, [PCINT]=0x000 Receive Ring rmd(FF002430): status 9000 length 76 address 2A313C4 rmd(FF002438): status 9000 length 76 address 2A31A44 rmd(FF002440): status 9000 length 60C address 2914424 rmd(FF002448): status 9000 length 60C address 2933B64 rmd(FF002450): status 9000 length 60C address 29334E4 rmd(FF002458): status 9000 length 60C address 2932E64 rmd(FF002460): status 9000 length 60C address 29327E4 rmd(FF002468): status 9000 length 60C address 2932164 rmd(FF002470): status 9000 length 60C address 2931AE4 rmd(FF002478): status 9000 length 60C address 2931464 rmd(FF002480): status 9000 length 60C address 2930DE4 rmd(FF002488): status 9000 length 60C address 2930764 rmd(FF002490): status 9000 length 60C address 29300E4 rmd(FF002498): status 9000 length 60C address 292FA64 rmd(FF0024A0): status 9000 length 60C address 292F3E4 rmd(FF0024A8): status B000 length 60C address 292ED64 Transmit Ring tmd(FF0024B0): status 5C00 length 48 address 2A7E768 tmd(FF0024B8): status 0 length 0 address 0 tmd(FF0024C0): status 0 length 0 address 0 tmd(FF0024C8): status 0 length 0 address 0 tmd(FF0024D0): status 0 length 0 address 0 tmd(FF0024D8): status 0 length 0 address 0 tmd(FF0024E0): status 0 length 0 address 0 tmd(FF0024E8): status 0 length 0 address 0 tmd(FF0024F0): status 0 length 0 address 0 tmd(FF0024F8): status 0 length 0 address 0 tmd(FF002500): status 0 length 0 address 0 tmd(FF002508): status 0 length 0 address 0 tmd(FF002510): status 0 length 0 address 0 tmd(FF002518): status 0 length 0 address 0 tmd(FF002520): status 0 length 0 address 0 tmd(FF002528): status 2000 length 0 address 0
tx_limited=0(16)
SCC GENERAL PARAMETER RAM (at 0xFF003C00) Rx BD Base [RBASE]=0x2430, Fn Code [RFCR]=0x18 Tx BD Base [TBASE]=0x24B0, Fn Code [TFCR]=0x18 Max Rx Buff Len [MRBLR]=1548 Rx State [RSTATE]=0x18000000, BD Ptr [RBPTR]=0x2440 Tx State [TSTATE]=0x18001FD2, BD Ptr [TBPTR]=0x24B8
SCC Transparent PARAMETER RAM (at 0xFF003C30) CRC Preset [C_PRES]=0xFFFF, Mask [C_MASK]=0xF0B8
buffer size 20000
PowerQUICC SCC specific errors:
0 input aborts on receiving flag sequence
0 throttles, 0 enables
0 overruns
0 transmitter underruns
0 transmitter CTS losts
Tx Errors: output_drops = 0 num_retransmissions = 0 Rx Errors: input_error = 0 giants = 0 input_frame = 0 input_abort = 0 input_crc = 0 input_overrun = 0
MPC860 SCC 4 statistics: Serial IDB at 0x81613B9C DCE Unknown (13), clock rate 8000000 idb at 0x81613B9C, driver data structure at 0x8161B6A8 SCC Registers: General [GSMR]=0x1980:0x00000030, Protocol-specific [PSMR]=0x0 Events [SCCE]=0x0000, Mask [SCCM]=0x001F, Status [SCCS]=0x02 Transmit on Demand [TODR]=0x0, Data Sync [DSR]=0x7E7E Interrupt Registers: Config [CICR]=0x00365F80, Pending [CIPR]=0x00004802 Mask [CIMR]=0x68200000, In-srv [CISR]=0x00000000 Command register [CR]=0x6C0 Port A [PADIR]=0x1100, [PAPAR]=0x9FCF [PAODR]=0x0000, [PADAT]=0x61FF Port B [PBDIR]=0x0BC0F, [PBPAR]=0x0F00E [PBODR]=0x00000, [PBDAT]=0x090FC Port C [PCDIR]=0x000, [PCPAR]=0x000 [PCSO]=0x8E0, [PCDAT]=0xF3C, [PCINT]=0x000 Receive Ring rmd(FF002730): status 9000 length 60C address 2A3E404 rmd(FF002738): status 9000 length 60C address 2A3EA84 rmd(FF002740): status 9000 length 60C address 2A3F104 rmd(FF002748): status 9000 length 60C address 2A3F784 rmd(FF002750): status 9000 length 60C address 2A3FE04 rmd(FF002758): status 9000 length 60C address 2A40484 rmd(FF002760): status 9000 length 60C address 2A40B04 rmd(FF002768): status 9000 length 60C address 2A41184 rmd(FF002770): status 9000 length 60C address 2A41804 rmd(FF002778): status 9000 length 60C address 292AC64 rmd(FF002780): status 9000 length 60C address 292A5E4 rmd(FF002788): status 9000 length 60C address 2929F64 rmd(FF002790): status 9000 length 60C address 29298E4 rmd(FF002798): status 9000 length 60C address 2929264 rmd(FF0027A0): status 9000 length 60C address 2928BE4 rmd(FF0027A8): status B000 length 60C address 2928564 Transmit Ring tmd(FF0027B0): status 5C00 length 18 address 2A8D418 tmd(FF0027B8): status 5C00 length 1C address 2A8DAF8 tmd(FF0027C0): status 5C00 length C address 2A8E1D8 tmd(FF0027C8): status 5C00 length 1C address 2A87AB8 tmd(FF0027D0): status 5C00 length 600 address 2A88198 tmd(FF0027D8): status 5C00 length 600 address 2A88878 tmd(FF0027E0): status 5C00 length 22C address 2A88F58 tmd(FF0027E8): status 5C00 length 18 address 2A89638 tmd(FF0027F0): status 5C00 length 1C address 2A89D18 tmd(FF0027F8): status 5C00 length C address 2A8A3F8 tmd(FF002800): status 5C00 length 18 address 2A8AAD8 tmd(FF002808): status 5C00 length 6 address 2A8B1B8 tmd(FF002810): status 5C00 length C address 2A8B898 tmd(FF002818): status 5C00 length 600 address 2A8BF78 tmd(FF002820): status 5C00 length 600 address 2A8C658 tmd(FF002828): status 7C00 length 22C address 2A8CD38
tx_limite
SCC GENERAL PARAMETER RAM (at 0xFF003F00) Rx BD Base [RBASE]=0x2730, Fn Code [RFCR]=0x18 Tx BD Base [TBASE]=0x27B0, Fn Code [TFCR]=0x18 Max Rx Buff Len [MRBLR]=1548 Rx State [RSTATE]=0x0, BD Ptr [RBPTR]=0x2730 Tx State [TSTATE]=0x18001FD2, BD Ptr [TBPTR]=0x27C8
SCC Transparent PARAMETER RAM (at 0xFF003F30) CRC Preset [C_PRES]=0xFFFF, Mask [C_MASK]=0xF0B8
buffer size 20000
0 overruns
Tx Errors: output_drops = 160 num_retransmissions = 0 Rx Errors: input_error = 0 giants = 0 input_frame = 0 input_abort = 0 input_crc = 0 input_overrun = 0
gwnowin#show atm vc VCD / Peak Avg/Min Burst Interface Name VPI VCI Type Encaps SC Kbps Kbps Cells Sts
0 1 8 35 PVC SNAP UBR 320 UP
gwnowin#show ip route Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2 E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, ia - IS-IS inter area * - candidate default, U - per-user static route, o - ODR P - periodic downloaded static route
Gateway of last resort is x.y.z.201 to network 0.0.0.0
x.0.0.0/30 is subnetted, 1 subnets C x.y.z.200 is directly connected, ATM0 S* 0.0.0.0/0 [1/0] via x.y.z.201
gwnowin#show atm map
gwnowin#
gwnowin#show interface atm0 ATM0 is up, line protocol is up Hardware is DSLSAR (with Alcatel ADSL Module) Internet address is x.y.z.202/30 MTU 4470 bytes, sub MTU 4470, BW 320 Kbit, DLY 6400 usec, reliability 68/255, txload 1/255, rxload 1/255 Encapsulation ATM, loopback not set Encapsulation(s): AAL5 AAL2, PVC mode 23 maximum active VCs, 256 VCs per VP, 1 current VCCs VC idle disconnect time: 300 seconds Last input 00:00:35, output 00:02:41, output hang never Last clearing of "show interface" counters never Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: fifo Output queue :0/40 (size/max) 5 minute input rate 0 bits/sec, 0 packets/sec 5 minute output rate 0 bits/sec, 0 packets/sec 22 packets input, 1328 bytes, 0 no buffer Received 0 broadcasts, 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort 3 packets output, 84 bytes, 0 underruns 0 output errors, 0 collisions, 2 interface resets 0 output buffer failures, 0 output buffers swapped out
