2620 IOS query for ADSL WIC
Nov 10, 2005 2 Replies
Hi folks,
Does anyone know which IOS image filename will work with my 2620 router to boot the ADSL WIC which is inserted in it? Or even if this card is supported by the router?
I've tried two images so far that said they support the ADSL WIC but both fail to recognise the card. At boot the POST says "unrecognised card in slot....etc, etc".
D Watt
The IP Plus IOS will support it but not sure about the 2620. Also it has to go into a 1FE2W or 2FE2W card too.
Matt
Any 12.3 mainline train should work, but it has to be a IP+ image. (ie. c2600-is-xxxxx or equivilent).
12.2 needed the T train after some rev, or some test releases, probably alot easier/better to go 12.3 mainline.
