FastEthernet card not working in 12008 router
Nov 02, 2005 1 Replies
I have Cisco router 12008. Here is the "sh ver" output:
**************************************************************************** Cisco Internetwork Operating System Software IOS (tm) GS Software (GSR-P-M), Version 12.0(30)S4, RELEASE SOFTWARE (fc1) Technical Support:
(c) 1986-2005 by cisco Systems, Inc. Compiled Tue 04-Oct-05 14:52 by tinhuang Image text-base: 0x50010E80, data-base: 0x536F0000
ROM: System Bootstrap, Version 11.2(17)GS2, [htseng 180] EARLY DEPLOYMENT RELEASE SOFTWARE (fc1) BOOTLDR: GS Software (GSR-P-M), Version 12.0(30)S4, RELEASE SOFTWARE (fc1)
cisco 12008/GRP (R5000) processor (revision 0x05) with 262144K bytes of memory. R5000 CPU at 200Mhz, Implementation 35, Rev 2.1, 512KB L2 Cache
507K bytes of non-volatile configuration memory.
20480K bytes of Flash PCMCIA card at slot 0 (Sector size 128K).
8192K bytes of Flash internal SIMM (Sector size 256K). Configuration register is 0x2102
WARNING: Old fab-loader in slot 1; use "upgrade fabric-downloader" to update WARNING: Old fab-loader in slot 2; use "upgrade fabric-downloader" to update WARNING: Old fab-loader in slot 3; use "upgrade fabric-downloader" to update WARNING: Old fab-loader in slot 5; use "upgrade fabric-downloader" to update WARNING: Old MBus agent ROM in some slots; use "upgrade mbus-agent-rom" to update
Also there is in SLOT 5 8 Port Fast Ethernet Copper card. The problem is, this card is not working. It tries to power up but after IOS download (I mean all that startup procedure these cards do in order to work) it puts itself into WAIT. Here is the "sh diag 5" output:
**************************************************************************** SLOT 5 (RP/LC 5 ): 8 Port Fast Ethernet Copper MAIN: type 46, 800-4543-03 rev A0 Deviation: 0 HW config: 0x01 SW key: 00-00-00 PCA: 73-3683-05 rev A0 ver 3 Design Release 1.0 S/N CAB04239U5R MBUS: MBUS Agent (1) 73-2146-07 rev B0 dev 0 HW version 1.2 S/N CAB04239VOD Test hist: 0x00 RMA#: 00-00-00 RMA hist: 0x00 DIAG: Test count: 0x00000000 Test results: 0x00000000 FRU: Linecard/Module: 8FE-TX-RJ45-B= L3 Engine: 1 - Standard OC48 (2.5 Gbps) MBUS Agent Software version 1.100 (RAM) (ROM version is 2.33) ROM Monitor version 16.4 Fabric Downloader version used 25.1 (ROM version is 24.5) Primary clock is CSC 0, Persistent LOS to slot 16 17 18 19 20 Board State is Waiting to retry download after persistent failures (RTRY WAIT) Insertion time: 00:00:16 (2d23h ago)
How can I make this card to work? Cards in slots 1, 2, and 3 work fine. Here is "sh diags summary" output:
**************************************************************************** SLOT 0 (RP/LC 0 ): Route Processor SLOT 1 (RP/LC 1 ): 4 Port Packet Over SONET OC-3c/STM-1 Single Mode SLOT 2 (RP/LC 2 ): 1 Port Gigabit Ethernet SLOT 3 (RP/LC 3 ): 1 Port Gigabit Ethernet SLOT 5 (RP/LC 5 ): 8 Port Fast Ethernet Copper SLOT 16 (CSC 0 ): Clock Scheduler Card(8) SLOT 17 (CSC 1 ): Clock Scheduler Card(8) SLOT 18 (SFC 0 ): Switch Fabric Card(8) SLOT 19 (SFC 1 ): Switch Fabric Card(8) SLOT 20 (SFC 2 ): Switch Fabric Card(8) SLOT 26 (PS B1 ): AC Power Supply(8)
Thanks for help
Igor
Hi Igor,
You may wish to contact Reggie Grant at Cisco Repair.
Toll Free: 877-549-2680 or 828-277-7272
Sincerely,
Brad Reese BradReese.Com Cisco Repair Service Experts
Hendersonville Road, Suite 17 Asheville, North Carolina USA 28803 USA & Canada: 877-549-2680 International: 828-277-7272
