Anyone tried to upgrade vxWorks AP to IOS using scripts (with conversionFirmware image and SNMP/tftp) ? without using WLSE or the Cisco conversion tool.
Thanks
Yes. After converting without the conversion tool the newly converted AP is at factory defaults. No problems, all you need is a TFTP server and it is best practice to have a console cable available if anything goes wrong. Something will go wrong, only if you don't have it ;-)
Read the full replyAnyone tried to upgrade vxWorks AP to IOS using scripts (with conversionFirmware image and SNMP/tftp) ? without using WLSE or the Cisco conversion tool.
Thanks
Yes.
Greetings,
Yes you can do it though you might need to do an archive download...
see the last few lines of the link below:
--Evan
