2611 with NM-16ESW
Sep 22, 2006 7 Replies
Jump to replies (7)
Anybody can help out?
I'm trying to use NM-16ESW in Cisco 2611. Cisco website suggests that this module works with 2611 from 12.2(8) with restrictions and in 12.3 w/o restrictions.
I tried up to 12.3(20), but router still do not recognise the module. I have several 2611s and several NM. All the same. Any ideas?
%PA-3-NOTSUPPORTED: PA in slot1 (Unknown (type 681)) is not supported on this image. Please issue "show diag" in fully loaded IOS image to get the PA's information and verify if it is supported by this image, a newer version may be needed. .......... Slot 1: Unknown (type 681) Port adapter Port adapter is disabled Port adapter insertion time unknown EEPROM contents at hardware discovery: Hardware Revision : 1.0 Top Assy. Part Number : 800-15156-02 Board Revision : A1 Deviation Number : 0-0 Fab Version : 03 PCB Serial Number : FOC09454Y6U RMA Test History : 00 RMA Number : 0-0-0-0 RMA History : 00 Unknown Field (type 00CF): 00 15 F9 9B 0E 3B MAC Address block size : 17 Product (FRU) Number : NM-16ESW Version Identifier (VID) : V01 EEPROM format version 4 EEPROM contents (hex): 0x00: 04 FF 40 02 A9 41 01 00 C0 46 03 20 00 3B 34 02
Network modules for the 2600, 3600, and 3700 series routers sometimes require a certain Cisco IOS Software feature set in order to be recognized.
ATM, voice, and switch modules require a Plus feature set, and Virtual Private Network (VPN) modules require an IP Security (IPSec) feature set in order to be recognized.
To determine the software requirements and to upgrade to a compatible Cisco IOS train, refer to:
Software Support for Hardware
section of the Software Advisor.
If the network module is still not recognized, verify that the installed Cisco IOS Software has the required feature set to support the module.
Issue the:
show version command
to determine the feature set.
This is a sample command output:
3725ESW>enable 3725ESW#show version Cisco Internetwork Operating System Software IOS (tm) 3700 Software (C3725-IS-M), Version 12.2(11)T6, RELEASE SOFTWARE (fc1) TAC Support:
(c) 1986-2003 by cisco Systems, Inc. Compiled Fri 14-Feb-03 18:50 by ccai Image text-base: 0x60008940, data-base: 0x617C4000
ROM: System Bootstrap, Version 12.2(8r)T2, RELEASE SOFTWARE (fc1)
3725ESW uptime is 1 day, 17 hours, 49 minutes System returned to ROM by reload System image file is "flash:c3725-is-mz.122-11.T6.bin"
cisco 3725 (R7000) processor (revision 0.1) with 196608K/65536K bytes of memory. Processor board ID JMX0715L02P R7000 CPU at 240Mhz, Implementation 39, Rev 3.3, 256KB L2 Cache Bridging software. X.25 software, Version 3.0.0. SuperLAT software (copyright 1990 by Meridian Technology Corp).
38 FastEthernet/IEEE 802.3 interface(s) DRAM configuration is 64 bits wide with parity disabled. 55K bytes of non-volatile configuration memory. 31744K bytes of ATA System CompactFlash (Read/Write)
Configuration register is 0x2102Look at the second line of the show version command output.
The feature set is designated by the characters between the dashes in the (C3725-IS-M) part of that line.
In this case, IS represents the feature set, which stands for IP Plus.
If there is an S present, it indicates a Plus feature set.
If the display shows (C3725-I-M), it indicates the Cisco IOS Software was a non-Plus version, and ATM, voice, and switch modules would not be recognized.
Always use this part of the show version command output to determine the feature set rather than the filename from the System image file is "flash:c3725-is-mz.122-11.T6.bin" line because it is possible that the file may have been renamed.
If a VPN module is not recognized, verify that the feature set is an IPSec version.
The characters which indicate this are 56 or K.
For example, (C3725-IK9S-M) or (C3640-IS56I-M) are IPSec versions.
If the feature set does not support the network module, upgrade the Cisco IOS Software to one with a compatible feature set.
For Cisco IOS Software upgrade instructions, refer to:
Software Upgrade Procedure
Hope this helps.
Wow, thanks a bunch!
I was misleaded by Cisco website that stipulates that only 12.2 requires IP or IPPLUS for this module, but it is still the case for
12.3 too.
Everything works now.
THANK YOU !!!
I had a look a this since the tool Brad pointed out was new to me.
It is all very confusing regarding the 2600 software.
Can you please post the output of the show ver command. i.e. is it an XM or not?
Here is sort of what I found:-
Very nice, thanks.
Says that 2611 (not XM - I didn't look that up) with NM-16ESW needs
Earliest Latest
12.3(7)T12 12.3(8)T11 12.4(1b) 12.4(3a) 12.4(2)T1 12.3(8)T11
any Feature set will do, well IP-Base is OK so I guess any one will do.
I would recommend 12.4 (not T) if it meets your other requirements.
BUT there is no 12.4 for 2611 (not XM) There is no 12.3T for 2611.
Here what worked for me:
ROM: System Bootstrap, Version 11.3(2)XA4, RELEASE SOFTWARE (fc1)le configuration ROM: C2600 Software (C2600-ADVSECURITYK9-M), Version 12.3(16a), RELEASE SOFTWARE
Processor board ID JAD04525ZVC (3997335338) M860 processor: part number 0, mask 49 Bridging software.
2 Ethernet/IEEE 802.3 interface(s) 16 FastEthernet/IEEE 802.3 interface(s) 1 Serial network interface(s) 32K bytes of non-volatile configuration memory. 16384K bytes of processor board System flash (Read/Writ
Software that were tried did not work:
12.3(9) 12.3(10) 12.3(10a) 12.3(18) 12.3(20)
This is not XM, plain old 2611.
Thanks,
I don't want to be difficult or anything. I just want to point out that the above elements of the sho ver do not show the hardware platform or the version. You have cut out the bits that matter most!!! :-))
I don't mind, its just for your information that I let you know.
Here is an annotated sh ver that I did with a fixed width font before pasting into GG. Hope it looks OK.
I am pleased that you solved your problem.
router1#sh ver Cisco Internetwork Operating System Software IOS (tm) C2600 Software (C2600-IK9O3S-M), Version 12.3(16a),\\ ^^^^^^^^^^^^^^ ^^^^^^^^ /FEATURE SET/ /VERSION/
RELEASE SOFTWARE (fc2)
Technical Support:
(c) 1986-2005 by cisco Systems, Inc. Compiled Wed 09-Nov-05 19:23 by evmiller Image text-base: 0x80008098, data-base: 0x81CAF568
ROM: System Bootstrap, Version 12.2(8r) [cmong 8r],\\ RELEASE SOFTWARE (fc1) ROM: C2600 Software (C2600-IPBASE-M), Version 12.3(6c),\\ ^^^ /ROM(s) - not normaly changed/
router1 uptime is 44 weeks, 5 hours, 33 minutes System returned to ROM by reload at 12:02:38 GMT Fri Nov 18 2005 System restarted at 12:10:27 GMT Fri Nov 18 2005 System image file is "flash:c2600-ik9o3s-mz.123-16a.bin"
This product contains cryptographic features and is subject\\ to United
If you require further assistance please contact us by\\ sending email to snipped-for-privacy@cisco.com.
cisco 2611XM (MPC860P) processor (revision 0x301) ^^^^^^ /HARDWARE/
with 126976K/4096K bytes of memory. ^^^^^^^^^^^^ /RAM memory/
Processor board ID M860 processor: part number 5, mask 2 Bridging software. X.25 software, Version 3.0.0.
2 FastEthernet/IEEE 802.3 interface(s) 32K bytes of non-volatile configuration memory. 32768K bytes of processor board System flash (Read/Write) ^^^^^^ /FLASH/
Yes he did. It's using the new packaging for IOS, not the old crusty IP PLUS type packaging. It's Advanced Security. Take a look here to familiarize yourself with the new IOS packaging names:
OK, Iet's consider that.
The thing that I don't understand then is that in the version information posted the lines began with the text "ROM:"
In no case that I have ever seen is this directly related to the IOS version running.
Here is an 857W with a software version that you may prefer: Router2#sh ver Cisco IOS Software, C850 Software (C850-ADVSECURITYK9-M), Version 12.4(6)T, RELEASE SOFTWARE (fc1)
ROM: System Bootstrap, Version 12.3(8r)YI2, RELEASE SOFTWARE
System image file is "flash:c850-advsecurityk9-mz.124-6.T.bin"
The first line shows the IOS version, the line beginning "ROM:" shows something else.
As far as I can see the information provided by the original poster was /not/ the IOS software version running on the box.
Please post a complete show ver output that shows the IOS version where the lines begin "ROM:"
The originall posted sh ver is clearly not complete, unfortunately as far as I can see the OP did indeed miss out the most critical information. The ROM version is something that you almost never have to be concerned about (unless you have of course some 8500s:-(()
If you disagree please convince me, since I want to try to understand as much as I can.
