Alcatel Speed Touch Home ?
May 24, 2005 3 Replies
Bertil Lindstrom
Thanks Amanda! I just found out the reason for no contact: I had not sat up the pc the the same net -:() When I assigned 10.0.0.130 as the adress of the PC, then it was "all systems go" !! Thanks anywhay! /Bertil
Hi out there!
I have a "Speed Touch Home" ADSL modem. Acording to the manual, the access to the modem setup is either via telnet or http on 10.0.0.138.
I have tried to ping the adress, but get no reply.
Is there a way my old ISP could have blocked the adress in the modem to prevent tampering? ( I bought it from them)
Or is there any other way in. There is no rs232 port what I can see.
/Bertil
Thanks Amanda!
Thanks anywhay!
/Bertil
That is the default. It may have been changed to another standard (I changed mine).
Try 192.168.1.1 or 192.168.0.1 for grins
Quoting Bertil Lindstrom:
Happened to me many times!
